The ARB you have will work with 30 spline Longs. By 27 spline they are refering to where the inner shart goes into the birfield joint. Stock is 27 spline. Bobby makes them stronger by adding 3 more splines in the birfield joint. As for the rear 3rd member, yes you can use it. It's still an 8" ring gear.
