« on: Dec 24, 2006, 04:51:52 PM »
I have never seen a north americian 3.0 that will not accept a pilot bearing.
Grey market engines are another subject.
I trust you will not have any issues with the pilot bearing.
Now reguarding wiring, swing pedals, cutting the added hole for the slave cylinder.....
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
