Shamb, do you have any pics of how you ran your lines to the fuel cell? What did you do with your tip over vent, just valve it or vent it to the exterior? Did you run AN line all the way to the carb or adapt it to regular fuel line? How about your filter and fuel pump?
Thanks, Dooner
I have pictures but none are of it completely done, i'll take some and post up later this week. I cut the stock lines right before the cab and used the existing for all the hookups, plus the vent. As for running the lines, I used 1 3/4" round tubing and just fed them through, I have a 16" piece that comes down the side of the fuel cell and then a 4' piece that runns under my rear tube bed along one of the outer tubes then out into the existing hardlines.
I used 3/8" hose and (3x) 3' sections of steel braided house up by the fuel cell.
This pic shows where I mounted it but the fuel lines are still loose because I hadn't mounted the verticle tube yet.
