Author Topic: rocker arm clatter ?  (Read 2340 times)
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: rocker arm clatter ?
« on: May 15, 2004, 10:28:07 PM »
Cold, adjust to .006 intake, .010 exhaust.
Hot, adjust to .008 intake, .010 exhaust.
You may also have worn rocker arm adjusting studs, and/or the end of the valve stem may have wear from excessive valve clearance.
Check to make sure that the rocker arms are centered on the exhaust valve stems of the #2, and #3 cylinders. I have seen the arms wear on the side and run off center.
Marlin
« Last Edit: May 15, 2004, 10:30:45 PM by Marlin »
Last post Mar 14, 2006, 04:20:25 PM
by toymech
Last post Jun 03, 2006, 08:27:31 PM
by waskillywabbit
Last post May 20, 2007, 09:15:37 PM
by nate650
Last post Jul 24, 2007, 08:24:39 PM
by ~tc~
Last post Mar 17, 2020, 10:48:44 AM
by sirdeuce
