« on: Apr 20, 2004, 11:30:02 PM »
I feel that the heavyweight flywheel is a waste for rock crawling. It is true that it helps the truck off the line, but you will lose power climbing hills.
I am not a fan of centerforce clutches due to the heat that they produce and the severe side load on the crankshaft thrust washers.
Marlin
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
