Author Topic: Front Axle Seal Replacement  (Read 3795 times)
synwars
  • Turtle Points: 360
  • Male Posts: 485
  • Member since Mar '05
  • Fabbing with Maffy
    • Can you feel the love?
Re: Front Axle Seal Replacement
« on: Apr 27, 2006, 10:59:53 AM »
If you want to just replace the oil seal for now, and rebuild later you can take the knuckle off using the modified Camo method.
Camo Method.
Usually you can get the whole knuckle off by taking the top steering knuckle off and then rotate the whole knuckle away and down from the axle. While you got your knuckle, hub, and axle out, clean out the old grease, repack with new grease. Change inner seal. Bolt back together. Good to go. :turtle:
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
Last post May 21, 2007, 10:36:03 AM
by dkg1869
Last post Mar 27, 2009, 11:40:09 AM
by BigMike
Last post Jul 12, 2010, 01:03:36 PM
by ninja turtle
Last post Nov 22, 2010, 02:49:17 PM
by lax815
Last post Mar 09, 2011, 11:27:58 PM
by BoG-ToY
