the 20r head on the 22r block is cake walk. the only reason the w56 isn't a straight bolt in is because the tranny is longer so won't bolt to your stock t-case, and you need to cut your floor for the shifter since there also in a different location. it will bolt to your block of course. so that is all you have to do though to make it work
