Author Topic: 20R on propane  (Read 17257 times)
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
Re: 20R on propane
« Reply #30 on: Dec 24, 2005, 03:17:22 PM »
propane won't make your truck go faster than gasoline(if you're comparing 2 identical engines, one running gas, one running pane), since it has less energy potential than gasoline.  however, it is very high octane so you can crank the compression up or run forced induction without pinging, which will translate into a lot more power.
the main benefit of propane is that you won't stall on angles like a carb, but doesn't require a complicated EFI swap.  most kits just use the throttle plate from your carb and mount a mixer assembly on top.
it's also much cleaner burning that gasoline, so clean that when you go to change your oil, it will still look nearly brand new.
Last post Apr 07, 2006, 08:10:31 AM
by AzBearFan
Last post May 08, 2006, 02:32:26 PM
by trax28to
Last post Jul 10, 2006, 10:29:33 PM
by KYOTA
Last post Aug 22, 2010, 10:03:09 AM
by tanabuse
Last post May 28, 2007, 08:33:21 AM
by Lady Di
