Author Topic: Installing a Weber on a 20R---Follow up  (Read 10280 times)
11 Bravo
  • Male Posts: 140
  • Member since Aug '05
  • Chicks dig scars
Re: Installing a Weber on a 20R
« on: Aug 22, 2005, 07:59:26 PM »
most weber kits required that you lose the EGR valve if you want to keep your PCV. the reason being that the weber kit has a plate with a fitting that goes on the EGR spot on the manifold, just plug your PCV hose into the fitting.
Thanks Kyle. I didn't get a kit. I got a pretty good deal on the carb used and bought the adapter stuff from LCE. I will be loosing the EGR one way or another, so I will look at making up a plate with a fitting. I may still go with a Weber manifold before this whole thing is over anyway.
I'm not very smart, but I can lift heavy things.
Last post Jun 20, 2005, 02:51:21 PM
by UNBREAKABLE
Last post Aug 10, 2008, 09:53:11 PM
by Mtn. Toy
Last post Mar 24, 2010, 01:18:30 AM
by iNfErNaL
Last post Dec 18, 2012, 12:39:40 AM
by toe
Last post Mar 01, 2018, 07:11:10 PM
by gdmcondev
