Author Topic: BigMike, do you recognize this place ??  (Read 3404 times)
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: BigMike, do you recognize this place ??
« on: Jul 03, 2005, 10:22:06 AM »
It is no wonder that after working in the same shop since '87, the Fire Marshall finally told me "clean this dump, or I will shut you down".
This pic must me at least 2-3 years old.
When we hauled the scrap away, we got $29.00 per ton.
Today, it is worth $80.00 per ton.
I recall hauling away 98 tires to the dump.
The old days of my Toyota wrecking yard. :smack:
Last post May 30, 2003, 11:29:04 AM
by 79coyotefrg
Last post Jan 26, 2008, 07:55:04 PM
by boggerunner
Last post Dec 12, 2009, 02:06:51 PM
by 69800
Last post Aug 05, 2012, 08:23:15 AM
by fordh8r
Last post Oct 27, 2018, 06:57:23 PM
by Noahrob
