Author Topic: 87 4Runner build Slowww build  (Read 11474 times)
Doable
  • Turtle Points: 69
« on: Apr 21, 2011, 08:28:11 PM »
This started a few years ago by convincing the wife how nice it would be to wheel a 4Runner instead of my 86 Extra cab. So here we go. I wound up locating a 87 4Runner in Austin,TX  RUST FREEEE . Well that was the good part the bad is it was a father and son project that the son gave up on so the father was tired of seeing it in his parking spot under the carport.Which means the engine and trans were torn apart and in boxes in the 4Runner. He was positive all the part were there to reassemble but we all know how that goes.
The interior was not in bad shape
It sat for three years then I got motivated to work on it for a trip  we had planned to go wheeling in Moab.So time for the IFS to be removed for the SAS.
 Found my donor truck for the SAS just in time before they crushed it at the scrap yard.
« Last Edit: Apr 21, 2011, 08:52:27 PM by Doable »
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
4Runner_kid
  • Turtle Points: -79
  • Male Posts: 302
  • Member since Jun '10
Re: 87 4Runner build Slowww buid
« Reply #1 on: Apr 21, 2011, 08:30:35 PM »
What are the plan's? Beside's sas.
1992 Toyota 4Runner: Trail Gear Front Bumper, WARN M8000, 1st Gen 4Runner Roll Bar, Back Up Light, K&N Intake, Magna Flow Exhaust, 15x8 Crager Soft 8's, 32x11.50R15 BFG KM2's, JDM Surf Inclinometer, Aisin IFS Hubs.
Doable [OP]
  • Turtle Points: 69
« Reply #2 on: Apr 21, 2011, 08:41:12 PM »
Guess I should not have waited so long to pull the tank or at least drain it when I got the truck. This is what it looked like. This project keeps costing more and more.
Started making my frame plates for both sides now that everything is all cleaned up.
The suspension will be the same as my Extra Cab RUF, F-150 in the rear. Really like the way they preform and keep the truck low.
BSLCA.com
Doable [OP]
  • Turtle Points: 69
« Reply #3 on: Apr 21, 2011, 08:47:40 PM »
The same as others I guess. Keep it low ,tube bumpers, sliders,lower geras with lockers . Try to build it once with out having to keep redoing everthing and wheel it, wheel it, and keep wheeling it  :greengrin:
BSLCA.com
Doable [OP]
  • Turtle Points: 69
Re: 87 4Runner build Slowww build
« Reply #4 on: Apr 22, 2011, 06:12:11 PM »
Nothing fancy at all, just wanted to clean up the dif because I tend to pull the drain plugs out.I had an old third member with cracked teeth that I used and bolted in tight to maybe help not warp the housing when I weld on it.
And added a fill plug higher than the factory one. Still need to put some armor on the diff to help protect the ring gear.
BSLCA.com
Zs Confederate Toy
  • Male Posts: 1,146
  • Member since Mar '11
« Reply #5 on: Apr 22, 2011, 08:08:09 PM »
Looks like a fun build
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
Doable [OP]
  • Turtle Points: 69
« Reply #6 on: May 31, 2011, 08:26:40 PM »
Was able to finish off the rear axle and installed the Marlincrawler 5.29 diffs. with lockers. With old school 35" MTR's this is the clearance.The third in the pictures is my spare to help keep things straight.
Got the front shaved down also.
Took almost two days of on/off cutting grinding and welding. I was trying to be carefull not to warp the housing, so i did not put to much heat to it when I would weld. Weld for a while then work on the spring pack. or the steering shaft. The third did not bind slippinng it into the housing and the Longfields both went in without binding.
BSLCA.com
Doable [OP]
  • Turtle Points: 69
« Reply #7 on: May 31, 2011, 08:51:45 PM »
The front springs are just mix matched with old leaves from different springs i had laying around. With good bump stops they will last a while.
With the rear suspension set with F-150 springs and the front with 87 RUF this is how it sits.
 Should have the front axles finished this week after I get finish clearness the knuckles
BSLCA.com
Zs Confederate Toy
  • Male Posts: 1,146
« Reply #8 on: May 31, 2011, 10:23:22 PM »
Lookin good
ZACH
87 Rock Rat X
Trail Junky
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #9 on: Jun 01, 2011, 06:01:00 AM »
is that brown primer or is all that new work rusted?
i lie kthe way it sits, looks good
Doable [OP]
  • Turtle Points: 69
« Reply #10 on: Jun 01, 2011, 07:43:17 AM »
Thanks. Mostly  rustoleum brown primer, but we do have a lot of humidity down here. Just makes me use the flapper wheel a little more. Moving the axle forward with the use of rear springs helps me not to have to trim the fenders like I did on my other truck.
BSLCA.com
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #11 on: Jun 01, 2011, 08:17:45 AM »
Nice start, looking good
Jrod
  • Male Posts: 65
  • Member since Jan '10
« Reply #12 on: Jun 05, 2011, 12:24:00 PM »
Looks like it's coming along sweet
Yota87Truck
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
« Reply #13 on: Jun 05, 2011, 11:13:16 PM »
Nice ride height.  Looks great
konarider1993
  • Turtle Points: -7
  • Male Posts: 101
  • Member since May '11
« Reply #14 on: Jun 06, 2011, 05:16:05 PM »
ill have to lower mine abit
Doable [OP]
  • Turtle Points: 69
« Reply #15 on: Jun 07, 2011, 01:02:45 PM »
Thanks for the complements on the 4Runner. Got both front knuckles cleaned out for the Longs to go in, thought I had good bearings in the front but after a good cleaning it shows that I had water in the front knuckle and the bearing show it, pitted pretty bad so now I’m waiting on more parts to show up from Marlin to put the front end together. Getting close to being done but man it seems like it will not stop.
BSLCA.com
Doable [OP]
  • Turtle Points: 69
« Reply #16 on: Jun 07, 2011, 08:32:02 PM »
Making room for the new axle shafts
 seeing where they will rub at it really was not much.
hopeing with the weight of the bumpers sliders and tools bags it will sit like my Extra cab does and it will be moving in the yard under its own power. 8)
BSLCA.com
prawl44
  • Male Posts: 63
  • Member since Apr '11
« Reply #17 on: Jun 07, 2011, 08:56:12 PM »
 :confused: why did you do that to the axle ?
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #18 on: Jun 07, 2011, 09:56:11 PM »
Nice build, coming along great. Also like your extra cab, I think I've seen it posted somewhere else  :dunno:
Doable [OP]
  • Turtle Points: 69
« Reply #19 on: Jun 08, 2011, 05:55:30 AM »
You mean painting the inside of the ball area of the axle? To see where the new Longfields would rub at. I allready have all the paint removed only needed it for test fit purpose.
BSLCA.com
prawl44
  • Male Posts: 63
« Reply #20 on: Jun 08, 2011, 05:37:11 PM »
o thats cool but i was wondering about the one you cut open
SloCrawler
  • Male Posts: 1,333
« Reply #21 on: Jun 08, 2011, 09:59:31 PM »
Shaving the diff, he's gaining ground clearance, you made that look easy
prawl44
  • Male Posts: 63
« Reply #22 on: Jun 08, 2011, 10:57:45 PM »
ooooo got yea still kinda new to this lol
88_YotaCrawler_88
  • Male Posts: 20
  • Member since May '13
  • Yota For Life
« Reply #23 on: May 16, 2013, 10:49:38 PM »
Wow some sick work! :respect:
Last post Aug 20, 2005, 09:12:01 PM
by crawlerdan
Last post Oct 06, 2005, 10:12:04 PM
by dentedfender
by toyhunter
by Kaos III%
Last post May 06, 2017, 04:38:31 AM
by Someday
