Author Topic: I wanna build a tacoma please help  (Read 5095 times)
spaceman
  • Turtle Points: -1
  • Male Posts: 24
  • Member since Jun '04
« on: Jun 21, 2004, 12:21:24 PM »
I have an 83 built for crawling and it still kicks butt on the hardcore trails, but I wanna build a rig that is comfortable to highway and can do moderate+ trails.  Does anyone out there have suggestions as to a good start, i.e. 2.7 vs 3.4 and what years are desireable?  I want a regular cab short bed and will swap in a solid axle and add crawler gears.
Any suggestions would be appreciated.
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • yellow beast
Re: I wanna build a tacoma please help
« Reply #1 on: Jun 21, 2004, 01:32:17 PM »
they're all pretty good, but you can only 95 and 96 had the regular cab with a v6 optional, it's pretty rare to find them but they're around(i'm gonna look for one for a DD eventually)
don't see why you'd need a straight axle for moderate trails, just get a locker.  the taco has coil spring suspension in the front, and if you find one from 2000 or earlier you can get locking hubs unlike that stupid ADD crap they all have now
WHITE_TRASH
  • Turtle Points: 679
  • Member since Feb '03
« Reply #2 on: Jun 21, 2004, 01:33:21 PM »
Id fine a 78-79 Bronco front axle (high pinion) and cut it down to use waggy axles.  Id keep the coile from the bronco as well and extent the radius arms at least 12" for a better ride and good flex.  Then get a Mco9(?) to use a crawler box and have fun!
spaceman [OP]
  • Turtle Points: -1
  • Male Posts: 24
« Reply #3 on: Jun 22, 2004, 09:45:55 AM »
Thanks for the input.
I wanna do a solid axle because I have an extra one and I have a suspension design I wanna try.  The bronco axle idea is good, but i just don't feel right using a Dana axle.  I also like the ground clearance if the Toy axles.
Ryan
WHITE_TRASH
« Reply #4 on: Jun 22, 2004, 10:42:57 AM »
The only reason that I suggested a dana axle is because the diff is on the driver side on taco's, not the passenger side like a earlier truck.  But if you get the adapter to run a low range box behind the current trans then you can use a gear driven case and the yota axle.
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #5 on: Jun 22, 2004, 01:10:15 PM »
The only reason that I suggested a dana axle is because the diff is on the driver side on taco's, not the passenger side like a earlier tuck.
96 and newer right ?
spaceman [OP]
  • Turtle Points: -1
  • Male Posts: 24
« Reply #6 on: Jun 22, 2004, 01:23:48 PM »
I forgot to mention that the axle I have is modified.  I cut the ends off and I can flip it over if I need to and put waggy 44 outers on it.  I know it's wrong, but I have the parts just lying around and I like to experiment.
Late model waggys have the correct drop for the project, a little less modifacation required than the bronco axle.
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #7 on: Jun 23, 2004, 04:07:16 PM »
EBs have a driver drop too...the main problem with those is that like everything for an EB, they're expensive
if i was gonna do something with a driver drop, i'd look for a '78-79 F150 or F250 HP44
spaceman [OP]
  • Turtle Points: -1
  • Male Posts: 24
« Reply #8 on: Jun 23, 2004, 09:50:40 PM »
What's EB?
I think high pinion is over rated, please enlighten me.
kyle_22r
  • Male Posts: 1,233
  • yellow beast
« Reply #9 on: Jun 26, 2004, 12:56:42 PM »
EB = early bronco.  high pinion gives you a better driveshaft angle, and all '78-79 fords had high pinion fronts.  not a bad idea considering most axles you'd put under a tacoma needs some work done, why not go all the way and just go high pinion?
a high pinion gearset is also stronger going forward since it doesn't run on the coast side of the gears except in reverse(just like your rear axle), but that's probably a wash
« Reply #10 on: Jun 26, 2004, 04:45:07 PM »
just got my 4wheeler mag today and guess what  :hammer:it shows Marlin and gang putting a crawler in a taco
81Toy4x
  • Guest
  • Marlin Crawler
  • I used to Crawl. I still do, but I used to, too.
« Reply #11 on: Jun 27, 2004, 05:30:16 PM »
Hey glen, what month issue is that?  I'd like to check it out!
« Reply #12 on: Jun 27, 2004, 05:37:49 PM »
august 04
4wheeloffroad.com
« Reply #13 on: Jun 27, 2004, 06:02:01 PM »
Last post Oct 28, 2006, 10:26:54 PM
by mudking82
by toyhunter
Last post Jun 06, 2019, 02:39:17 PM
by X-Toy Driver
Last post Jun 08, 2010, 09:49:09 AM
by 3.4Runner
Last post Nov 12, 2010, 09:22:20 AM
by BoG-ToY
