Author Topic: 1982 rescue project  (Read 441 times)
See1do1teach1
  • Member since Feb '19
1982 rescue project
« on: Feb 22, 2019, 07:27:59 AM »
Hey everyone.
 Slowly exploring this rabbit hole of off-road building. I have a 1982 SR5 long bed 4wd. Never worked on vehicles until purchasing it. A needed rescue from middle Georgia. From a kid who was abusing his daddy's truck. In fact I had to repeat the five hour round trip twice, after discovering the truck was his daddy's, in order to buy it. Idled as low as 1200rpm, but I didn't know better. So like a naive first animal adoption, I quickly realized I was into more than I thought I was bargoning for.  Took me 4 years to really rise to the challenge. It sat in the garage until recently. In the last two years I rebuilt the drum brakes, carburetor, front knuckles, and put in a new front main seal (You guys who eat these projects for lunch are amazing). All with the help of my father-in-law, Toyota repair manual, and the interweb. The short term goal is regear, lift, paint, and go play. So thank you in advance for the knowledge I am sure to gain in here!
On that note I joined the forum to find a thread stepping through the Yukon ring/pinion project I dove into last week. You don't know what you don't know until you know your stuck. Can someone can direct me to a thread(trouble finding answers to these questions) or help learn me what wisdom I need.
Question 1: does the old pinion height help me in any way?(worth repressing the old races while the old pinion gear still has bearing and shim installed?)
Question 2: is it worth honing the OLD rear bearing,once pulled, to slide on and off the NEW pinion gear while seeking new pinion depth?
Question 3: what portion of the pinion to carrier assembly needs to be installed when measuring pinion height, AND should I use the old crush spacer at this point? (I don't have the SST that the repair manual wants me to utilize)
« Last Edit: Feb 22, 2019, 08:17:51 AM by See1do1teach1 »
Last post Feb 16, 2009, 12:03:58 PM
by SeanFoster
Last post Nov 20, 2009, 07:06:36 PM
by Farace1979
Last post Oct 11, 2012, 08:39:02 PM
by MRHilux87
Last post May 16, 2013, 10:06:56 PM
by bigarms23
Last post Apr 30, 2021, 07:26:34 PM
by blackdiamond
