Author Topic: Thoughts On what Is Broke  (Read 2048 times)
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« on: Nov 18, 2018, 10:03:16 PM »
Any thoughts on what has broken on my front case? Click the link to see the issue.
https://www.facebook.com/Spinnin4s/videos/2078085345596079/
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
Re: Thoughts On what Is Broke
« Reply #1 on: Nov 19, 2018, 07:04:44 AM »
Did you remove the shifter base. May see a bit more
Rocksurfer [OP]
  • Momentum Man
  • Lego Enforcement
« Reply #2 on: Nov 19, 2018, 09:01:54 PM »
No, just the shifter. I can clearly see something rotating then stop with it in gear, once it stops it locks up and won't rotate at all and will kill the engine. A little more info on the shifter, when shifting the front case into low the shifter will continue past the normal spot it rests at like it is pushing the gear further than it is supposed to.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #3 on: Nov 19, 2018, 11:48:34 PM »
User Error
 :cheese:
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #4 on: Nov 24, 2018, 07:43:13 AM »
You will not know until you pull it and open it up!! Time to get greasy!!
Rocksurfer [OP]
  • Momentum Man
  • Lego Enforcement
« Reply #5 on: Apr 12, 2019, 10:14:33 PM »
So I know it has been a while and I have had it fixed for a while so that I could go to KOH but I thought I may let everyone know what was the issue with my tcase and unfortunately I think it is a design flaw in the shift rod. What happened was the welded, cut and trimmed rod snapped where the trimming of the plate that the shifter mates to. From what I could see the plate requires to have a cut in it for clearance, that cut created a weakness in the plate that over time and heavy use will work back and forth until in snaps. The fix is to weld a small piece of metal on the rod instead of using the plate no clearance needed.
Last post Mar 31, 2006, 02:28:57 AM
by germ
Last post Jul 15, 2007, 11:32:31 PM
by Tool Pimp
Last post Feb 09, 2008, 09:46:19 PM
by skipnrocks
Last post Mar 19, 2008, 01:52:27 PM
by bigarms23
Last post Jul 04, 2009, 02:17:13 PM
by JoeWelder
