Author Topic: Hydrolocked 22re  (Read 10788 times)
Mudder
  • Turtle Points: 3448
  • Member since May '15
Re: Hydrolocked 22re
« Reply #30 on: Oct 05, 2016, 02:26:40 PM »
Yes it is an Engnbldr cam. He even recommended it to me based on how my engine was setup. Ted's a great guy, but it's hard to be the stock cam.
blackdiamond
  • Turtle Points: 1173
  • Male Posts: 4,898
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #31 on: Oct 05, 2016, 03:56:36 PM »
Did you get your 261 directly from ENGNBLDR? There's a lot of imposters on eBay according to Tod..
Since i installed the cam, my torque range is from about 1750 through 4250 ish.. on Gnarly's rebuild post we debated this, and I'm still waiting to get an actual dyno, but that's what my butt dyno says haha..
Like i said, different strokes ya know. You can say I'm wrong all day but that doesn't make it so.
Once i get the dyno, I'll either be buying a different cam or I'll be really happy..
Sent from my LG-H830 using Tapatalk
If you're happy why would having dyno numbers on paper change that?
ExCabSwap
  • Turtle Points: 1043
  • Male Posts: 682
  • Member since Jan '16
  • 3rd Gen ExCab Swap!
    • Buy me a soda
« Reply #32 on: Oct 05, 2016, 04:01:11 PM »
Because if my cam is causing me to only have 85 HP or something, I'll be upset haha..
I dunno, I'll probably just keep what I've got
Projects waiting in my shop: '83 Front Axle, TG Sliders, second tcase, NEW: XD 4.70 gears!
blackdiamond
  • Male Posts: 4,898
« Reply #33 on: Oct 05, 2016, 09:09:41 PM »
If you're happy then I would suggest not finding out and risking your joy.
ExCabSwap
  • Male Posts: 682
    • Buy me a soda
« Reply #34 on: Oct 06, 2016, 01:40:10 PM »
Good point
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #35 on: Oct 08, 2016, 06:51:48 AM »
Machinest says the block is virgin(never been bored or milled), no cracks. Crank is fine. However, the head was milled .040 too much from the last guy. Have to buy a new head and swap over all the valves n such. Of course, all new rods
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #36 on: Oct 16, 2016, 09:37:08 PM »
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #37 on: Oct 19, 2016, 09:27:55 PM »
I think this is what they're supposed to look like  Got it back from the machine shop and now installing all of the goodies. I hope to have her running this weekend
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #38 on: Oct 22, 2016, 05:47:24 PM »
Exactly!!! Got it all buttoned up except for the hood. Hit the ignition and click, click. Upon some investigating, the motor is locked up. I even put the long ratchet and socket directly on the crank. The only thing that went on that i am second guessing is the new marlin clutch and flywheel that i installed. This is only a guess. I'm wondering if the old fly wheel may have been a little thicker and took up a millimeter or two. For it to be locked up solid like this, i gotta hunch it may be the flywheel bolts hitting the block. I'll pull the motor in the morning. To be continued....
Snowtoy
  • Turtle Points: 809
  • Male Posts: 2,455
  • Member since Sep '03
« Reply #39 on: Oct 22, 2016, 06:25:04 PM »
Did the crank turn before you installed it?
OVRAROK
  • Turtle Points: 23649
  • Male Posts: 2,828
  • Member since Dec '10
« Reply #40 on: Oct 22, 2016, 06:38:04 PM »
theres 2 bolts that hold steel plate on, the plate that on before the flywheel, those bolt heads are thinner then most. could be hanging up on flywheel
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #41 on: Oct 22, 2016, 07:07:20 PM »
I didn't think to check if it turned after putting the plate and and clutch assy. I should have just because thats what i should have done. @ovrarok i totally forgot about those thinner headed bolts. I bet you're right
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
Hydrolocked 22re
« Reply #42 on: Oct 23, 2016, 10:50:59 AM »
I re read my initial post and i should have worded it a bit different. It reads as if i was blaming the clutch. I was just brainstorming. Thanks ovrarok for bringing that bit of info to my attention. Sho nuff, it was that stinkin bolt. I just trimmed it a little and back in we go...
Oh, and Snowtoy, i did turn the motor this time
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #43 on: Oct 23, 2016, 10:51:10 PM »
It was over cast this morning and then it rained on and off all day. Eazy up to the rescue and continued the install
ll
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #44 on: Oct 23, 2016, 10:52:16 PM »
OVRAROK
  • Male Posts: 2,828
« Reply #45 on: Oct 24, 2016, 07:21:30 AM »
that's  a clean looking 4runner  :thumbs:
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
  • irish redhead texan, interesting combo
« Reply #46 on: Oct 27, 2016, 01:32:35 PM »
Well done! So what's the next set of plans for it?
read and comment :whip:
USAF EOD tech
Last post Mar 03, 2007, 04:06:19 PM
by Tallchevy
Last post Mar 26, 2007, 01:36:56 PM
by Cheesemaker
Last post Apr 22, 2010, 02:11:27 PM
by greenseaman
Last post Jul 08, 2015, 10:09:55 AM
by Bananaclip
Last post Sep 24, 2013, 12:47:01 PM
by 88sasturbotoy
