1991 Toyota Hilux Sunrader 4WD Diesel Camper Motorhome - $22500 (Estacada)
This unique recently imported motorhome is a rare find!
2.7L DIESEL ENGINE / 4 WHEEL DRIVE / RIGHT HAND STEERING / LOW MILES / REAR DUALLY / 5 SPEED TRANSMISSION / FIBERGLASS CAMPER / TV / BACKUP CAMERA
OVERHEAD BED / AWNING / SOLAR PANEL / LADDER & ROOF RACK / SPARE TIRE
STAINLESS SINK / MICROWAVE / REFRIGERATOR / ALL THIS AND MORE!!!
GENERAL
Body type Truck
Drive PART 4WD
Transmission 5 speed manual
Displacement, cc 2779
Frame S-LN106-TRMSS
ENGINE
Engine model 3L
Max.power (Net), kw(PS)/rpm 91 ps (66.93 kw) / 4000 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.2 kg*m (188.29 N*m) / 2400 rpm
Power density 17.03
Engine type Water cooling serial 4 cylinder OHC
Fuel system Bosch type distribution type (jet pump)
Fuel type Diesel
Compression ratio 22.2
Bore, mm 96
Stroke, mm 96
Final gear ratio
Fuel consumption at 10-15 modes, l/100km
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering
Tires size, front 215R15-6
Tires size rear 215r15-6
Braking system, front Disk
Braking system, rear Drum (leading/trailing)
Suspension system, front Semi- elliptic leaf spring
Suspension system, rear Semi- elliptic leaf spring
