What gasket(s) are you using for transmission shifter?
what do you have now
A roof tent so i can pretend to be an overlander.
Maybe if you work in the accent a bit more, you could try and blend in with the Aussies? Those guys are born overlanders. Come out of the womb with an ARB quick deflator in hand.
Your missing the point.
You’re missing the apostrophe and an e. Disclaimer: All in good fun.
My wit fails me.
Is English your second language or is our English in it's second country?
My English can't be arsed when i'm cold and wet, which is what i was when i typed the original.I can't believe the Grammar Nazi has been had by a Grammar Nazi.Just unacceptable.
Nate are You sure it’s a transmission concern?I reread the description You wrote and there’s not really enough information to eliminate other possibilities.Could it be the rear diff or t-case?
maybe it was the transfer case after all?T-case rebuild kit arrived on Wednesday. Hopefully that solves the problem.
its a possibility, its got trail gear innardsand bits of mashed up nastiness in it, when i pulled the stick out of it when the G Series took a it looked like the gears had been sand cast in a hovel in Delhi.
trail gear innards? Please be more specific.
Trail Gear 4.7 and top shift kit, which leaks for some funny reason
I didn't realize it had 4.7s in it. Here I thought You did all that Cali wheeling with Andrew and the boys with 2.28s in the Tcase. Didn't realize You had cheated with Trail gear 4.7's. I'm not sure I can look at you the same again Steven.
Started by BigMike Chit Chat Camp
Started by Blue Screamer New Member Check-In!
Started by yotamckimboy4x4 Project Research and Build-Ups
Started by sinbob « 1 2 3 » Project Research and Build-Ups
Started by yota_2128 Project Research and Build-Ups
