Nice rig! Have you had problems running the 4Ds with yota axles?
Do you already have the uni mogs?
LolIve only seen mogs a few times, most people don't realize how long the pinion is on them. Are you going to stretch the wheelbase quite a bit?
Will be watching! looks like it will be an awesome build!
If for some bizarre reason you tear into the drop boxes make sure when you reassemble them that you do it correctly, Dont mix gears up put each dissasemble box into a box on its own and mark it as such. if you dont the thrust created by the bevel gears will jack the housings apart and crack the casings, seen it been on the side of the road fixing it.... So you might want to make sure you establish which of the two is the 'front' or even if its been setup correctly.Have you considered having housings made to suit the knuckles and drop boxes? Cos i know for a fact them diffs are heavy as hell especially when your putting em in on your own. Would also give you greater gearing options.Off the top of my head the diffs are 3.5:1 and the portal drop boxes are 2.summin:1 giving you 7.summin :1 axle ratio.
Thank you for your input, its certainly helpful in case that i over look something!! Yeah, i'm definitely aware of the portal gears and the issue if you put them on backwards. Not from experience luckily. lol I've actually got 2 full sets of 404 axles and a good buddy of mine has 2 complete Mogs. Since the guy that i bought the axles from set them up so long ago, he didn't remember which axle is which (front vs rear), so i'm gonna pull them apart to verify that they will be driving on the right side of the gear to be on the safe side. Plus, i've got one portal box leaking gear oil anyhow. naw, I'm not gonna swap the housings. These ole gals are certainly heavy. The double wall housing definitely make em a bit heavier but i'm not too terribly worried since the weight will be down low. In regards to the gearing, you are right on the money...they are 7.56 geared but I'm not looking for top speed. haha
I was thinking along the lines of a 5.29:1 diff ratio with the portals thats 10:1 without the dual cases....Ive cut two sets of cases now and converted them for right hand drop t cases, theres a lot of work in it....
Started by burl4x4 Engine
Started by 86turboyota Engine
Started by rednk1980 Toyota Pickup/4Runner Tech 1979-95
Started by KDXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by 79coyotefrg Toyota Pickup/4Runner Tech 1979-95
