Author Topic: 83 3rz / matching boat  (Read 49420 times)
redneckcustoms13
  • Turtle Points: 6285
  • Male Posts: 2,292
  • Member since May '15
Re: 83 daily driver build
« Reply #90 on: Jun 13, 2015, 07:09:36 PM »
It made the road trip home. Still have to finish up ac, build bumpers, change gears to 4.38 because the 4.56 is a littlw too much for my liking on 33s. Found out there is a short somewhere in the tail/running lights tonight.
01 double cab hunting truck
06 tacoma street truck
redneckcustoms13 [OP]
  • Male Posts: 2,292
« Reply #91 on: Jun 13, 2015, 09:16:13 PM »
It had a few stored codes. Did the 10k ohm .5 watt  resistor in the egr temp sensor. Got rid of all except the auto trans codes. I've been back through the 3rz thread. Has anyone found a solution other than a manual ecm. All I can find is one for $200 on ebay.
Before resistor.
Resistor
10 mile drive afterward
  • Male Posts: 2,292
« Reply #92 on: Jun 15, 2015, 07:59:05 AM »
After the day of puting shaft in and puting interior back together ans driving it home I love it. Put over 250 miles on it this weekend. It pulls my hunting boat well.
As figured the valve cover is leaking. Grabbing some seals might swap it this evening
liveoak
  • Turtle Points: 115
  • Member since Mar '08
« Reply #93 on: Jun 15, 2015, 08:50:30 AM »
Did you mean 4.88 not 4.38?
my 3rz swap. http://board.marlincrawler.com/index.php?topic=97722.0
Let me start off with a basket of chips
  • Male Posts: 2,292
« Reply #94 on: Jun 15, 2015, 03:26:24 PM »
No, meant 4.38
donteatbugs
  • Member since Jun '15
« Reply #95 on: Jun 16, 2015, 03:20:50 AM »
The only complaint I really had was the throttle cable that was used seems like it was binding. that or the carbon buildup on the back of the throttle body is making the plate stick shut. It has a lot more power than the last 83 I worked on, thats for sure.
  • Male Posts: 2,292
« Reply #96 on: Jun 16, 2015, 04:53:41 AM »
All I can say to anyone who is removing a carburetor 20/22r in the plan for fuel injection is this. Do not waste your time with a 22re. They are great engines, not knocking them for their reliability. The 3rz is hands down the best thing I have done to a 1st gen. Running 5th gear on interstate at 70 you can easily roll into it and pickup speed to pass someone. It's more fuel efficient as well. I am very grateful for the 3rz swap thread that big mike and many others contributed to. It basically covers everything except wiring and that would be a whole 48 page thread in its on. If you can get on line and find a fsm for both your donor vehicle and your current vehicle your good. It takes some patience (something I am not blessed with) but if you can solder you can do it.
  • Male Posts: 2,292
« Reply #97 on: Jun 16, 2015, 04:55:23 AM »
Re routed the cable if you look above ben. It helped tremendously.
  • Male Posts: 2,292
« Reply #98 on: Jun 16, 2015, 07:29:51 PM »
After hunting all over the place for a 3rd gen top plate I gave up. I got to thinking about this strange looking compressor that was on an 87 carburetor 2wd parts truck I had. So I went up there this evening and grabbed it. Also on this 83 it had a little 90° 3/16" line that is discontinued at the dealer ship so robbed one off the parts truck that was quite a bit longer. Had to make some extra bends but it fit and it's on. The top plate bolted onto the taco compressor. The low side line hooked to the firewall just fine. The other would connect to the dryer if it were a few inches shorter but just put a lot of bind on it the way it is so it will get shortened and a new end crimped on tomorrow.
First, this is a 1993 22re pickups top plate, the top plate faces forward. It would work great as well as lines if I could have found one...
This is what I ended up having to use of the 87.
  • Male Posts: 2,292
« Reply #99 on: Jun 17, 2015, 06:55:50 AM »
Working on some cheap 10" shocks to get on the front end.
 And finally rinsed the wheels off .
Miller
  • Turtle Points: 79
  • Male Posts: 74
« Reply #100 on: Jun 17, 2015, 08:42:11 AM »
Looking good man.  Coming right along.
 :respekt:
93 Runner, 86 Runner build, 85 Bobbed, 85 Xcab for parts
  • Male Posts: 2,292
« Reply #101 on: Jun 18, 2015, 05:13:09 AM »
Now the ac is kicking right along. Looking for a pair if 8" fans to run on the condenser. At idle the 134 builds a little too much head pressure and can't stay cool. Also have to do some ring about exhaust. It is way too loud.
  • Male Posts: 2,292
« Reply #102 on: Jun 18, 2015, 07:36:22 PM »
Today it finally got shocks. Didn't have the funds for hoops, and had a set of f250 towers in the shed so just used them. Also hit the u pull it looking for fans. That was a fail, but did get a pair of jl audio 6.5s and a pair of jl 5.25s for $10.
LittleSteve
  • Turtle Points: 6
  • Male Posts: 872
  • Member since Jan '14
  • I dont even have a Toyota
    • Buy me some coffee
« Reply #103 on: Jun 20, 2015, 02:04:46 AM »
Im taking notes.....i do like this truck.
I dunno what it is, whether its the stance, the fact its a get it working and use it build idk.
I just know i like it
Bydd eich meddylfryd cul yn eich cicio i fyny'r asyn
Mae'r dyfodol yn drydan
  • Male Posts: 2,292
« Reply #104 on: Jun 20, 2015, 09:19:39 AM »
Thanks steve. My main reason for not going all out on high dollar parts is because it is a daily driver that will see little offroad use. It pulls the little boat and takes me where I need to go. Already have 2 trail rigs(80 pickup, 85 4runner) so not much reason in making this one another chewed piece of bubble gum lol.
This morning back to muffler shop to install a 25" resonator before the muffler. It helped quite a bit. Still has a littlw tone to it, but it got rid of the raspy popping it had.
Made some 3/16 gussets for the cross member mounts.
Painted and mounted the ecm.
SqWADoosh
  • Turtle Points: 10316
  • Male Posts: 2,376
  • Member since Oct '14
« Reply #105 on: Jun 21, 2015, 11:54:11 AM »
Looking good, Hunter.  :thumbs:
  • Male Posts: 2,292
« Reply #106 on: Jun 22, 2015, 06:34:29 PM »
El cheapo ebay $23 headlights until I can afford leds.
  • Male Posts: 2,292
« Reply #107 on: Jun 24, 2015, 10:56:20 AM »
I'll take pictures later when I mount the fans. During lunch I cut the grill to clear the fans going on the condenser, removed the "steering cooler" line and routed it to transmission cooler section of the radiator. Held about another quart and a half of fluid so that should be good.
  • Male Posts: 2,292
« Reply #108 on: Jun 25, 2015, 06:04:42 AM »
8" fans. They are thicker than the advertised size so more grill trimming is in order.
Cleaned up and old long field shift knob might put it on when the axles gets in there.
  • Male Posts: 2,292
« Reply #109 on: Jun 25, 2015, 07:24:55 PM »
This evening put the two fans on a 30 amp relay fed by the ac idle up circuit. Also put a toggle switch on the signal wire between the relays. Not only do fans only come on with the ac compressor, but I can hit the switch and cut the fans off while cruising so they aren't always turning and adding more drag to the alternator. I let it idle for almost an hour on max ac and the high side line feeding the dryer from the bottom of the condenser never got too hot to hold your hand on so the fans appear to be doing their job.
  • Male Posts: 2,292
« Reply #110 on: Jun 26, 2015, 05:54:01 PM »
Ran across this boat last night in Craigslist. Just had to get it to complete the early 80s theme.
donteatbugs
« Reply #111 on: Jun 28, 2015, 04:00:37 PM »
Gonna do a motor swap on the boat too?
  • Male Posts: 2,292
« Reply #112 on: Jun 28, 2015, 06:33:57 PM »
Well... it only done 32 mph yesterday with with a 13 3/4 x17 today it got 32 with a 13x19. Still slow as can be. She just might end up with a 2.4 200 merc that's making about 220...
LittleSteve
  • Turtle Points: 6
  • Male Posts: 872
« Reply #113 on: Jun 29, 2015, 02:55:24 AM »
You seen them outboards that are basically an ls2 v8 ?
http://youtu.be/Yun1kpHi-Qs
http://youtu.be/zrTzWDC6E6o
« Last Edit: Jun 29, 2015, 03:20:33 AM by LittleSteve »
  • Male Posts: 2,292
« Reply #114 on: Jun 29, 2015, 05:21:49 AM »
Seven makes some wicked outboards! This little turd is just a family cruiser. Still have the hydrostream vector in the shed if I want to go get my 90 mph itch scratched lol
kjchubby
  • Turtle Points: 531
  • Male Posts: 34
  • Crawlin PNW
« Reply #115 on: Jun 30, 2015, 04:12:50 PM »
Diggin the build man. Keep up the good work. :eyebrow:
Tow Pig: 1995 Dodge Cummins 12v, 4' MBRP turbo back exhaust, GlowShift A-Piller Gauges, Adjustable Boost Elbow, 2.5" leveling kit, 35" BFG AT KO's, BHAF
Trail Rig(The Smurf): 1982 Toyota Pickup, 22r, Red top Optima, 63's/RUF's, 38's, 5.29's, open front, spool rear
  • Male Posts: 2,292
« Reply #116 on: Jul 01, 2015, 04:46:53 AM »
Thanks. Haven't done much to it other than drive it daily. Hauled Alot of scrap metal, pulled the boats, just about doing its job. Hopefully after this holiday weekend I can get back on it and try to fit the bumpers and make mounts.
  • Male Posts: 2,292
« Reply #117 on: Jul 14, 2015, 08:17:11 AM »
After putting almost 3,000 miles on in. I do not in any way regret the swap. Fuel mileage is not what I was expecting (16-17) I believe that is due to the wheel and tire choice. The 4.56 is staying need to round up a front diff with 4.56 so lockers can get ordered. Then build a front shaft, install the longs and what not. Hitting a brick wall with the bumper mounting plans. Got a friend at work that's going to help with the writers block I have going on. Maybe we can figure something out once we are both looking at it with the bumper in front of it.
  • Male Posts: 2,292
« Reply #118 on: Jul 21, 2015, 06:50:22 AM »
Yesterday was an epic fail. Went to Barry's got a steering box from a 93 4runner, a dual diaphragm brake booster from a 90 model 2wd v6 auto truck, and the seats from a 87 accord. Got home and the booster won't clear the 3rz intake so I ordered one for an 87 turbo pickup (dual diaphragm but still small) tried the steering box swap (mine is leaking) the 86 box that I have is shorter than the 3rd gen box, so fail on that as well. Moved on to seats. Nowhere near a bolt in and roll out deal. Faught it for over an hour before I got pissed and went inside to eat. Maybe this evening I can build some plates to make the seats go in.
Current seats.
Plan to install
nwflyoda
  • Turtle Points: 36
  • Male Posts: 251
  • Mall Crawler
« Reply #119 on: Jul 21, 2015, 08:00:08 AM »
Man bud...she is coming along very nicely!!!!
84 Yota Pebble Pounder
Last post Apr 18, 2004, 07:12:26 PM
by case xx
Last post Mar 22, 2005, 09:56:30 AM
by 86 4runner
Last post May 18, 2006, 08:43:34 AM
by toyo487
Last post Jan 12, 2007, 08:28:22 PM
by Plowking
Last post Mar 08, 2008, 10:12:41 AM
by crawler94
