Author Topic: 83 3rz / matching boat  (Read 49450 times)
redneckcustoms13
  • Turtle Points: 6262
  • Male Posts: 2,332
  • Member since May '15
Re: 83 daily driver build
« Reply #150 on: Oct 16, 2015, 07:58:59 AM »
Bumper is doing it's job, I torched the old hitch off the other day, ans put led bulbs in the headlights. Just driving it daily, trying to find a place to mount an air filter box to make the intake a little less noisy. Also going to dig into the iac again to see if I can get it to high idle when engine is cold.
01 double cab hunting truck
06 tacoma street truck
redneckcustoms13 [OP]
  • Male Posts: 2,332
« Reply #151 on: Oct 29, 2015, 05:22:51 AM »
No real updates, rear pinion seal is leaking going to tear into that next week. Still looking for a 4.56 or 4.88 3rd so I can finish the front axle uo with longs and what not.
OVRAROK
  • Turtle Points: 21609
  • Male Posts: 2,591
  • Member since Dec '10
even the most primitive society has an intimate respect for the insane
  • Male Posts: 2,332
« Reply #153 on: Oct 29, 2015, 08:59:09 AM »
Thanks for trying. He doesn't know how to update his posts I called and he sold it.
SqWADoosh
  • Turtle Points: 10357
  • Male Posts: 2,439
  • Member since Oct '14
« Reply #154 on: Oct 29, 2015, 12:44:04 PM »
Too bad you live in BFE bama. There are 3rds for sale left and right in Toyotaworld aka the PNW.
  • Male Posts: 2,332
« Reply #155 on: Oct 29, 2015, 12:59:00 PM »
We have 2 local u pull it junk yards that sell them for $50, unfortunately all I've found lately is 3.90 and 4.10. Patience will get me a set of what I need eventually, I hope
  • Male Posts: 2,332
« Reply #156 on: Nov 12, 2015, 07:59:45 AM »
Have got to do something for rear springs the factory 2wd springs ride great but have no support for any kind of load.
SqWADoosh
  • Male Posts: 2,439
« Reply #157 on: Nov 12, 2015, 08:30:15 AM »
I know that feeling. My All-Pros flex like a mad man but put any weight in the back and she ends up looking like this:
  • Male Posts: 2,332
« Reply #158 on: Nov 12, 2015, 08:38:30 AM »
I can't decide what I want to do. I know I'm not doing 63s but chevy c10 springs look good, the Rangers I did research and they don't do loads well, not doing a lift spring simply for the reason you stated above. Open to opinions
mudmaster
  • Turtle Points: 2145
  • Male Posts: 2,610
  • Member since Feb '05
« Reply #159 on: Nov 12, 2015, 09:47:10 AM »
Custom?? Deaver, etc
Time to go wheelin!
  • Male Posts: 2,332
« Reply #160 on: Nov 12, 2015, 09:48:11 AM »
I have a ton of spring laying around, might go that route and just poke some more into the existing pack to get more out of it.
SqWADoosh
  • Male Posts: 2,439
« Reply #161 on: Nov 12, 2015, 10:07:30 AM »
F-150 swap is the best from what I read/hear.
jangelfire
  • Turtle Points: -1
  • Member since Jan '15
« Reply #162 on: Nov 12, 2015, 11:18:00 AM »
Love my f150 springs!
  • Male Posts: 2,332
« Reply #163 on: Nov 12, 2015, 11:25:00 AM »
Did you ever have them before going flat bed?
jangelfire
  • Turtle Points: -1
« Reply #164 on: Nov 13, 2015, 07:30:34 AM »
Negative but should work good with a bed also. Think the front hanger moved 8.5" forward
  • Male Posts: 2,332
« Reply #165 on: Nov 13, 2015, 07:36:35 AM »
Rear stays in factory location correct?
  • Male Posts: 2,332
« Reply #166 on: Nov 28, 2015, 10:06:38 AM »
Yesterday on the way home from the boat launch throttle cable broke. I got another one to get me by until a permanent solution is made. Anyone have suggestions on a cable the will work without having to fork up the firewall? The little universal Mr gasket snapped at the factory soldered end that comes on it.
« Last Edit: Dec 02, 2015, 07:14:49 AM by redneckcustoms13 »
liveoak
  • Turtle Points: 115
  • Member since Mar '08
« Reply #167 on: Nov 28, 2015, 08:15:34 PM »
have you seen the ZUK mod for Toyota rear springs? I like the second one using jeep coils because it can return to stock easily. http://www.gearinstalls.com/coilphilbert.htm
I did not do this, just showing what some people have done. I'm running 1st gen Tacoma all pros on mine (mounts relocated) https://www.allprooffroad.com/9504tacomarearsuspension/9504leafsprings , had to add a leaf, should have got the expedition ones
« Last Edit: Nov 28, 2015, 08:23:27 PM by liveoak »
my 3rz swap. http://board.marlincrawler.com/index.php?topic=97722.0
Let me start off with a basket of chips
  • Male Posts: 2,332
« Reply #168 on: Nov 29, 2015, 02:31:51 PM »
Hmm, that's some interesting stuff. I suppose I'll take a crack at rhe f150 swap simply because I do quite a bit of towing with it and loading the bed with junk. I'd like to just be lazy and slap some air shocks on it but I'm concerned with the flexing that it would rip them.
  • Male Posts: 2,332
« Reply #169 on: Dec 01, 2015, 04:48:07 AM »
Throttle cable is annoying me.  :tantrum: It's got small sticky spots in it and I know it's going to break again. I looked at a few 4wd 1st gen cabs at the house and they have a different pedal. So I guess I'll go to the junk yard and grab a tacoma throttle cable, use a 4wd throttle pedal, and as bad as i hate to do it, cut the firewall so it will fit. :rivers:
  • Male Posts: 2,332
« Reply #170 on: Dec 02, 2015, 05:35:14 AM »
Hit the u pull it after work yesterday and got a throttle cable from a 96 2wd 2rz taco. Got it home and looked at rhe difference. A 1st gen 4wd cable mounts very similar to a re or rz truck. However a 1st gen 2wd throttle cable threads through the firewall into a threaded block welded to the inside of the cab. I did not want to remove that I'd the reason for attemptimg to use the universal cable. That cable never was as smooth as a factory job, and after breaking one I knew something must change. I took a 17mm open end wrench and twisted back and forth on the threaded block until it broke free. Inserted the tacoma cable and secured it to the firewall gen the inside with 2 self tapping screws for temporary purpose until I have someone that can hold the roll when I insert machine screws and nuts. With the cable mounted I moved to the pedal. Again. A 4wd 1st gen pedal the top where the viable mounts is similar to the re/rz trucks, a 2wd is not it uses the same round lug as the throttle body end except smaller. I removed the 2wd pedal assembly and held a 4wd (from a parts truck out back) next to it to see the length of the pedal rod vertically was about 3/8" longer on the 4wd. The mounting surface that goes to the fire wall with 2 bolts in it is also different from 2wd to 4wd. I put the 4wd pedal rod onto the 2wd mounting bracket. Hooked it all up and it sets a little higher than the cable but not enough to worry about. Holy crap we have a smooth pedal boys! She is smoother than the pedal in my tacoma. I dig it! Now just to figure out how to re attach the rotten rubber pedal part to the floor...
  • Male Posts: 2,332
« Reply #171 on: Dec 02, 2015, 05:37:01 AM »
While at the above mentioned pull a part, I spotted abut 20 f150s. There is a 94 4wd wthe leafs hanging ready for the taking, and a 92 2wd ready for the taking. Is there a difference in the 2wd and 4wd springs? Also early 90s is what I'm looking for correct
jangelfire
  • Turtle Points: -1
« Reply #172 on: Dec 02, 2015, 05:52:35 AM »
The 2wd are softer and better flex for wheeling.mine came off of a 2001 2wd i believe
jangelfire
  • Turtle Points: -1
« Reply #173 on: Dec 02, 2015, 05:54:00 AM »
Ill look for the reciept and get a part # after work today
  • Male Posts: 2,332
« Reply #174 on: Dec 02, 2015, 05:55:36 AM »
There a quite a few of those out there as well.
OVRAROK
  • Male Posts: 2,591
« Reply #175 on: Dec 02, 2015, 06:05:46 AM »
Mid 80's to late 90's 2wd f150's, the mid 80's up because they come with teflon pads at the tips stock
  • Male Posts: 2,332
« Reply #176 on: Dec 02, 2015, 06:15:13 AM »
Did some pirate research and found that 4wd are 3" and 2wd are 2.5" so the 2wd it is. I might te to go grab a set this evening if it isn't raining.
« Last Edit: Dec 02, 2015, 07:13:55 AM by redneckcustoms13 »
J_Cole92
  • Turtle Points: 450
  • Male Posts: 271
  • Member since Dec '12
« Reply #177 on: Dec 02, 2015, 08:25:42 AM »
yeah mine on the 4runner are early 90's 2wd F150's 2.5" wide 3 leaf with an overload.
92 4Runner built on Toyota axles
84 Xtra Cab stock Daily Driver
55 Willy's Pickup Cab
Can't find it grind it
4runner build: http://board.marlincrawler.com/index.php?topic=96221.0
  • Male Posts: 2,332
« Reply #178 on: Dec 02, 2015, 08:28:57 AM »
I'm hoping not to have to move the rear hanger, we will see how it goes once they are in hand, re drilling leaf springs is a pain!
jangelfire
  • Turtle Points: -1
« Reply #179 on: Dec 02, 2015, 12:04:15 PM »
Heres my reciept for 2wd 1997
Last post Apr 18, 2004, 07:12:26 PM
by case xx
Last post Mar 22, 2005, 09:56:30 AM
by 86 4runner
Last post May 18, 2006, 08:43:34 AM
by toyo487
Last post Jan 12, 2007, 08:28:22 PM
by Plowking
Last post Mar 08, 2008, 10:12:41 AM
by crawler94
