Author Topic: 83 3rz / matching boat  (Read 76303 times)
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« on: May 28, 2015, 10:00:08 AM »
Hey to everyone and a big thank you to all of you that have put up the great info on all the informative threads. I have a few rigs, built quite a few for myself and with friends for them. This one will be my daily driver.
Started with an 83 2wd auto longbed, enjoyed it for a few months and built a new 22r for it. Ran it for another year or so and had a flat tire. That led to the sas. Left it 2wd auto until the time was right to finish it. But the head gasket let loose on me 3 years ago and it has been sitting  ever since.
« Last Edit: Feb 05, 2019, 08:15:14 PM by redneckcustoms13 »
01 double cab hunting truck
06 tacoma street truck
Miller
  • Turtle Points: 79
  • Male Posts: 74
Re: 83 daily driver build
« Reply #1 on: May 28, 2015, 10:17:44 AM »
Funny how a flat tire leads to SAS.  Years back a twisted driveline lead to a 4 link rear for me.  Sometimes just need a reason.  Any will do.
93 Runner, 86 Runner build, 85 Bobbed, 85 Xcab for parts
redneckcustoms13 [OP]
  • Male Posts: 2,513
« Reply #2 on: May 28, 2015, 10:39:27 AM »
Yeah I agree. It was either $80 for a 225/50-15 tire or $150 for a spring hanger and shackles. So I went that route.
  • Male Posts: 2,513
« Reply #3 on: May 28, 2015, 10:41:59 AM »
Pics from whrn we done the sas at a friends shop a few years ago
  • Male Posts: 2,513
« Reply #4 on: May 28, 2015, 10:44:23 AM »
  • Male Posts: 2,513
« Reply #5 on: May 28, 2015, 10:47:13 AM »
Sept 23, 2012 removing 22r sat ever since until a few weeks ago
  • Male Posts: 2,513
« Reply #6 on: May 28, 2015, 10:55:11 AM »
Ended up with a totalled 96 taco for a fair price and got all the goods needed from it. Unfortunately it was an auto, but our club is primarily toyota and a few of us having tacos for daily drivers rounding up a w59 bellhousing wasn't too hard. Taco had been sitting for over 6 years that I know of maybe longer. So since Feb when I got it home its cylinders had been soaking in marvel mystery oil just to be on the safe side. A few weeks ago pumped it all out and got it running. Got a fuel tank from a 94 pickup and swapped it in, only to find out it doesn't bolt up in the rear without a body lift so I put some 2" spacers in until I make a metal bracket for it. Rebend taco supply line. After mating the w56 behind it we dropped it in yesterday and discovered the engine was leaning almost 10° too far. Shimmed with washers and got it to 6°. Today I'll make some aluminum spacers. A 3/8" between isolator and frame, and a 1/4" between isolator and engine mount on block. Should do the trick. I hope so atleast. Then to address the issue with the firewall and rear of engine being only a 1/2" from each other and the wiring harness resting on the firewall.
Miller
  • Turtle Points: 79
  • Male Posts: 74
« Reply #7 on: May 28, 2015, 10:57:55 AM »
Wow, quite a transformation.  Nice rig, dig the color.  Reminds me of my first '83 I had in the late 80's.
  • Male Posts: 2,513
« Reply #8 on: May 28, 2015, 11:02:55 AM »
Pedals blasted and primed
 W56 was a dirt road soldier so we had to clean him a little
Pedal assembly ready to go in. Cleaned up
R vs RZ series bell housing
Trans oil was surprisingly in decent shape
mini header swap from parts engine that's locked up
Old cracked manifold
  • Male Posts: 2,513
« Reply #9 on: May 28, 2015, 11:03:58 AM »
Thanks miller. I love the brown as well. Unfortunately it isn't as perfect as the west coast trucks are but after some body work and 4wd fenders it will be good enough for my liking.
  • Male Posts: 2,513
« Reply #10 on: May 28, 2015, 11:05:59 AM »
Did the egr delete with some plates I made, swapped to t100 pan and pickup tube
Cleaned I up with some stuff we got to try at work. It's like clr but made by another company. Sucks on grease, but cleans the hell out of aluminum without giving it that dark look that alumibrite does to cast parts.
Does a great job on small surface rust as well
Mounts swapped, oil pan, dipstick, and pickup tube
Had to leave the original in there until a freeze plug is gotten to replace it
  • Male Posts: 2,513
« Reply #11 on: May 28, 2015, 11:07:17 AM »
Some tank comparisons while doing that swap
Closest tank is efi 2nd/3rd gen, far tank is 1st gen long bed
Taco left 22RE right
  • Male Posts: 2,513
« Reply #12 on: May 28, 2015, 11:08:57 AM »
Re bent the taco supply linr, was planning on having to cut and flair it, but it actually worked perfect. Doesn't look as nice as a factory job would, but for a re bent 20 year old line it isn't too bad.
3rd gen tank is not "bolt in" like all the threads on pirate and marlin say it is. They obviously have a body lift or cut the rib off their bed floor to clear it. Temporarily put some 2" long 1/4 pipe with some waters on it to space it until I can build a permanent solution.
  • Male Posts: 2,513
« Reply #13 on: May 28, 2015, 11:10:41 AM »
Ready to drop in
  • Male Posts: 2,513
« Reply #14 on: May 28, 2015, 11:12:30 AM »
We poked it in there last night to find the issues with clearance and leaning. After shimming still had 6° so making some aluminum spacers this evening to correct it.
« Last Edit: Mar 15, 2016, 12:45:11 PM by redneckcustoms13 »
  • Male Posts: 2,513
« Reply #15 on: May 28, 2015, 08:02:35 PM »
Shimmed passenger side and got it to 4°. 3 and a half hours later after cutting the other side mount all apart and cutting over a half Inch out of it we got the motor to 1° . Transmission cross member looks much better now. I can live with 1°
That is 1/2 of spacing on passenger side
  • Male Posts: 2,513
« Reply #16 on: May 29, 2015, 05:36:30 AM »
it is too close to the firewall in my opinion
but atleast its now level
cut over a half inch out of this guy even after adding a half inch to the other side
HogCanyonHopper
  • Turtle Points: 7333
  • Male Posts: 1,224
  • Member since Jul '10
« Reply #17 on: May 29, 2015, 06:10:36 AM »
awesome build  :thumbs:  Long bed ftw!!!  :burnout:
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
  • What is this Toyota you speak of?
    • Buy me some coffee
« Reply #18 on: May 29, 2015, 06:47:13 AM »
What he said, no point having a truck if you cant get most of an 8x4 in the back....
Refusing to fit in or comply.
Easy is not worth anything.
  • Male Posts: 2,513
« Reply #19 on: May 29, 2015, 10:53:15 AM »
Thanks guys I couldn't agree more. I've always had long bed trucks. Folks say they are not as nice but I like to have a box packed with tools and still be able to haul something as well. Plan to get fror cross member finished up today, down pipe on, and a friend is coming in the morning and we will try to get her wired for detonation :fingers crossed:
  • Male Posts: 2,513
« Reply #20 on: May 29, 2015, 12:09:14 PM »
Radiator just arrived. Can't beat ebay on that. $165
Miller
  • Turtle Points: 79
  • Male Posts: 74
« Reply #21 on: May 29, 2015, 12:42:36 PM »
Will that drop in or will you have to fab it up?  I need to find one for mine.
  • Male Posts: 2,513
« Reply #22 on: May 29, 2015, 01:01:41 PM »
It's just a 3.blow replacement. Should bolt into a 1st gen. Will certainly drop and go in your 2nd gen your building. (I'm sorry I can't bring myself to call an 84 up runner a 1st gen when the trekker came first lol)
Miller
  • Turtle Points: 79
  • Male Posts: 74
« Reply #23 on: May 29, 2015, 01:09:38 PM »
It's 2nd gen to me too.
  • Male Posts: 2,513
« Reply #24 on: May 29, 2015, 01:18:24 PM »
Glad to see I'm not alone lol, but yes sir it should be a bolt in job. Just get on ebay and search toyota 3.0 radiator. It came from somewhere in cali
  • Male Posts: 2,513
« Reply #25 on: May 29, 2015, 09:15:08 PM »
Well, went to u pull it and got a fuse block from a mid 90s corolla to power the fuel pump and other good stuff. Also grabbed a spare valve cover and various bolts/fuses. Got home to put the v6 3 core radiator in and it would bolt directly in, however the hood wouldn't close. If folks are running body lift then it would be perfect. I ended up lowering it about 2". I'll gets pics tomorrow. Loaded it up on the trailer and went over to pops in laws house to use his nice mig welder to finish up the t case mount. Got it done so tomorrow my buddy ben (has much more toyota wiring knowledge than i) is coming down from monroeville (2 hours north) to help get her energized.
  • Male Posts: 2,513
« Reply #26 on: May 30, 2015, 01:33:31 PM »
My friend got called into work so today I hot the air intake sorted out at the exhaust ran.
84 yota dude
  • Member since Nov '14
« Reply #27 on: May 30, 2015, 07:45:54 PM »
Clean work dude!
  • Male Posts: 2,513
« Reply #28 on: May 31, 2015, 07:11:42 AM »
Thanks. The exhaust is a littlw cobbled there at the end my buddy cut a littlw too much off and after bending realized it was too short. But can't complain when they don't charge you for it.
  • Male Posts: 2,513
« Reply #29 on: May 31, 2015, 06:13:44 PM »
done a quick easy job on the intake, do you guys see any possible issues with it?
Used a 3rd gen heater control valve. 1 hose is from the 3rd gen. Other is from taco.
Last post Apr 18, 2004, 07:12:26 PM
by case xx
Last post Mar 22, 2005, 09:56:30 AM
by 86 4runner
Last post May 18, 2006, 08:43:34 AM
by toyo487
Last post Jan 12, 2007, 08:28:22 PM
by Plowking
Last post Mar 08, 2008, 10:12:41 AM
by crawler94
