Okay, thanks for the information. I checked out your axle rebuild thread btw and I think I'll use it for reassembly. If I were to go with Aisin hubs, would I need to change anything else? I wasn't sure if they would mate up to the spindles that came with the Warn Birfield Eliminator kit.
One of your front springs should have come with a spacer for this exact reason.
Well, I guess I'll have to fab up a spacer and probably hunt down some longer u-bolts because the ones on the truck now won't accommodate a spacer.
Stock springs were arched different to make up the difference. Aftermarket are arched the same hence the need for a spacer to get it to sit level. On stock housings I used a piece of 3/8 flat bar welded to the stock spring perch. Drill a hole in it for the spring pin.I ran a Birfield Eliminator kit (not Warn) for about five years until one day it let go. Not only did it blow the kit but the shock load took out the ring and pinion, the u-joint on the other axle and the locking hub.The bad thing about the Warn locking hubs is they do not use the cone washers to keep them tight, when they loosen a bit it shears the studs and the locating pins on the hub that hold the locking hub on, We had it happen on a friends rig this year on the Rubicon. After a couple hours we replaced the studs and he checked the tightness a bunch of times on the way out. every time he checked, they were loosening up. here is a picture of the broken Birfield Eliminator kit . You can see it is junk!!
Was that the same guy who had Marlin drilling out his knuckle for him?
Started by MiniSimp Engine
Started by 808-Yota Engine
Started by awhotrods Parts For Sale
Started by big nate Newbie Questions
Started by Isaaccaza « 1 2 » Axle/Differential/Steering
