Author Topic: Diesel GOAT: The one I wish Toyota would have built  (Read 205834 times)
LittleSteve
  • Turtle Points: 170
  • Male Posts: 943
  • Member since Jan '14
Until they are sold, are they ever really done?
Dunno, you may be the expert on that...
Refusing to fit in or comply.
Easy is not worth anything.
LittleSteve
  • Male Posts: 943
It will never be done. There always changes that can be made, different turbos, better axles and suspension, fun gadgets to build for the interior.
Yeah but is it done yet?
  • Turtle Points: 1174
  • Male Posts: 5,053
  • Crawlin with Marlin
"Done" is defined as you're able to use it as originally planned and if you never added anything it would be a want and not a need.
helipilot77 [OP]
  • Turtle Points: 1018
  • Male Posts: 1,728
  • Member since Jul '12
  • Seattle, WA
    • My build thread
I must have missed it - Did the 1KZ-TE swap into the 1988 4Runner require new engine mounts and custom oil pan? I thought the 3VZ-FE, 5VZ-FE, and 1KZ-TE all shared the same engine mounts and trans (R150/151)?
The 4runner is an 1987. So it came with a 22-RE. Yes I did have to fabricate motor mounts. I ended up redoing them when I rebuilt the motor to lower it and give them a better angle. There were photos of the work on page 17
https://board.marlincrawler.com/index.php?topic=98969.480
bigwill837
  • Member since Jul '17
Thanks so much for the info.
I want to swap a 1KZ-TE into a 1st gen Tacoma. Do you know if the R150F transmissions are the same between the 1KZ-TE and the 3.4 liter 5VZ-FE? I thought I read that the bellhousing and input shaft is slightly longer on the 1KZ-TE version. Can I just use my original 5VZ-FE transmission and bellhousing on the back of the 1KZ-TE engine? I realize you used a R151F transmission.
TIA!
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
The bellhousing on the 1KZ-te is specific to that engine and has the starter motor on the opposite side. The bellhousing is still available from Toyota Europe brand new. The input shaft I believe is also still available. This would allow you to use your R-150f I obviously haven’t  done this but it seems like I have heard of others doing it. I dont see any reason why it couldn’t be done.
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
Rockcrawlintoy and I are trying to figure out at time that we both have off work so we can go wheeling. Does that meet the definition?
bigwill837
10-4. Did your 1KZ-TE engine come with an R151F (and appropriate bellhousing/input shaft)?
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
No. It came with an auto. I had to hunt down a R151f and order the bellhousing, flywheel, and clutch
LittleSteve
  • Male Posts: 943
I have an R15-- to kz bellhousing somewhere. just saying.
Is it done yet?
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
People contact me on occasion when they are doing this swap. I can sell it for you if you want to ship it over.
LittleSteve
  • Male Posts: 943
I have to find it first
  • Turtle Points: 26840
  • Male Posts: 3,508
  • Member since Dec '10
Steve....hope all is well for you and the wife...
LittleSteve
  • Male Posts: 943
Hey Dave,
We're all good thanks, yourselves?
calux
  • Turtle Points: 93
  • Member since Aug '20
Way back in the very beginning of this thread you mentioned a sweet custom triple stick setup for your duals; do you have any details you'd be willing to share?  you mentioned it was different from the radesign's setup in that it didn't require a bodylift/trans tunnel cutting.  getting ready to put duals in an 85 surf and your triples sound very intriguing
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
Yeah. I’ll have to dig up those photos and post pictures.
calux
  • Turtle Points: 93
thanks much appreciated  :beer:
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
Not the greatest photos but you can kind of see what I did. I made two low profile housings, one for each T-case. Then I used some brass o-ring fittings to seal around the sliding rods so that don't leak oil. I added a breather to each housing since the t-cases are vented through the shifters. each sliding rod is attached to a finger that engages the shifter rods inside each of the t-cases. each rod is connected through a linkage to a shift lever. it works very well and has only let me down once when my motor mounts tore off on a trail and bent one of the rods and left me stuck in low range. I was able to fix it on the trail, but I had to limp home to fix the motor mounts. since then the motor mounts have been completely re-done.
calux
  • Turtle Points: 93
did you have to do any trans tunnel cutting with this setup?  left and right links look like they'd clear just fine; definitely a slick setup
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
No tunnel cutting at all. I bent the linkages so they would clear. A setup like this would almost be mandatory on a pickup with a bench seat.
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
New Carpet:
+ 50 street cred.
+ 80 HP
+ 300 Wife Points
- 10 Decibels Turbo spool...I almost didn't do it.
« Last Edit: Nov 20, 2020, 11:41:15 AM by helipilot77 »
LittleSteve
  • Male Posts: 943
done that oil cooler yet?
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
No. But I did some more cleaning on it. I have another #1 fuel injector leak I gotta fix first. It is washing the whole side of the motor with diesel. I have a new injector pipe on the way. Everything else is new so it has to be the pipe.
In other news this is happening:
« Last Edit: Sep 12, 2020, 01:38:35 PM by helipilot77 »
dewiseman
  • Turtle Points: 56
  • Member since Sep '17
 :biggthumpup: glad to see you still have it going.  Have you gotten out for some wheeling lately?
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
No. No wheeling. Haven’t had any time with my daughter now.
dewiseman
  • Turtle Points: 56
 :clap2: CONGRATULATIONS
how old is she?
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
how old is she?
She is 15 months old so maybe when she is a little older we’ll go wheeling.
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2120
  • Male Posts: 2,338
  • RIP Kyle
I have been pretty busy, maybe after we get a little snow we can hit some forest roads!
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
RB
  • Turtle Points: 93
  • Male Posts: 75
  • Modify Everything
Snip... I made two low profile housings, one for each T-case.
I’m almost to this point myself, can you share more detail on the shift linkage you made?  Pics or drawings?
Cheers!
88' 4Runner
Build Thread
helipilot77 [OP]
  • Male Posts: 1,728
  • Seattle, WA
    • My build thread
Cheers!
I thought I had them posted in here somewhere I guess not.
Last post Feb 06, 2009, 09:36:31 PM
by twistedtoy92
Last post Oct 14, 2010, 09:39:10 AM
by Fleetwood
Last post Nov 26, 2008, 11:19:26 AM
by JohnHalladay
Last post Jun 19, 2009, 10:25:10 AM
by Pat
Last post Jul 17, 2020, 10:49:44 AM
by FjordWarrden
