I sure do hope you and your truck make it next year, I just love a well built diesel.I wanna see this truck in person
Just read your thread. Great job on the install.I just purchased a 1kz-te 88 4runner. Had the same running hot issues I purchased a 3 core alum radiator from Malaysia, had to cut and re weld the lower output, and the fan shroud inserts were also in the wrong hole. It also hit the hood. I re drilled the mounting bracket to lower the radiator. When I got the truck it would not go over 65 mph on flat ground without it going into the red zone…PO told me he had the same issue but it ran fine up to 65…I checked the fan clutch as I had to refill my prior land cruiser but it was fine. Put the new radiator in and I can run up a 6% grade with ac on in 100 deg heat and the temp never goes past ½ mark now, and it will run 75 to 80 in the flats now.Where did you source your engine FSM?And any ideas for small parts?, I need a turbo drain gasket where it goes into the block.luckily I did not hurt the head gasket on mine. Did you get your head on ebay?
you swapping heads for a lil more power?
looking at valve spring compressors... I might get this one or make one out of a large C clamp.//www.youtube.com/watch?v=XsF1lkNCfcE
I have a spare one you can have.
The rims look like they match even, is that Steve's truck in back ground trying to photo bomb
He might get emotional.
And?
looking good, is that pattern for bellhousing same as 22re, looks close.
hey nate, do you think that motor would run off b100?
So its like a w59 bellhousing just not crooked?
I did it for 3 years in my 12v. It's Alot of work. When fuel is as cheap as it is now it's not really worth messing with in my opinion.
Yeah, but fuel will be expensive again as soon as the Saudis have successfully ran our national oil producers out of buisness.
so I could run waste veggie oil.
I run it on B100 all the time. I would eventually like to build a second fuel tank with a heat exchanger in it so I could run waste veggie oil.
Starter and release are reversed.
you already are...
you realize the filter heads out of the 2L UK trucks have a heating element in them? I happen to have two..... you want one?
I didn't know that. I always wondered because my engine fuse box has a circuit labeled fuel heater. I definitely take one!! My filter primer is kaput anyways.
Started by twistedtoy92 « 1 2 » Rig Gallery
Started by Yotaman80 « 1 2 3 » Project Research and Build-Ups
Started by JohnHalladay General 4WD Discussion
Started by Halladay General 4WD Discussion
Started by FjordWarrden Project Research and Build-Ups
