Do it!
If you care, you can always redo the interior latter when you have more time, money and practice. The important thing is that it is functional now. The vinyl paint you are talking about is plasti dip. I wouldn't recommend it for your use. It peels off too easily. Because it peels off some easy, it would make a good product to test out color schemes to see how you like them.
hey look at this
Well I went to the auto clinic today, said $190 for replacing pinion seal. She's leaking. And I don't know how to get that crush nut sleeve off. Any tricks I should know about, before I before I go drop 2 bones to the shop?
With a hammer hit a small chisel between the nut and sleeve to bend it back and then remove the nut.
It takes a big breaker bar and a new nut. You just have to force it off. I don't know of any way to un-stake it.
Started by Skinny_Pedal Yoterhome Tech
Started by kletzenklueffer Rigs For Sale
Started by BigMike Project Research and Build-Ups
Started by BigMike Toyota Pickup/4Runner Tech 1979-95
Started by Chinook/fj55 Yoterhome Tech
