Author Topic: 3.0 V6 knowledge and tricks  (Read 2675 times)
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« on: Jan 15, 2015, 10:25:57 PM »
 :smack: those engineers must have been smoking some good drugs when they came up with some of these weird designs.
changing a timing belt on a truck of a friend, it wouldnt run at all. they replaced the fuel pump and distributor and then called me when they couldnt get it going.
  I saw that the thing wouldnt run at all with it timed "right" and when I pulled the timing cover I found this.
now it was pretty obvious how the tension idler came off but there was no obvious way to remove the center idler so after looking up the part and seeing the picture I found that it went on the block behind that tin cover.   Next I found either the upper intake had to come off to  see those bolts or the cam sprockets had to come off so the tin cover would come off.   THAT is what I did to get to the bolts although it was a tight fit but I got the dang thing off :wall:
also note that the three studs that hold the thermostat housing are LONG and go through the water pump and into the block.  (i will get a pic of that tomorrow)
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 3.0 V6 knowledge and tricks
« Reply #1 on: Jan 15, 2015, 10:36:04 PM »
Don't the 3.0s blow head gaskets before you need to remove the center pulley?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
79coyotefrg [OP]
« Reply #2 on: Jan 15, 2015, 11:08:50 PM »
well maybe but this one has 275,000 on it. and hasnt had a new belt in 150,000
zippo
  • Turtle Points: 569
  • Male Posts: 1,554
  • Member since Nov '08
    • oppiz.net
« Reply #3 on: Jan 15, 2015, 11:47:25 PM »
I have done the 3.slow timing belt and don't remember it being that bad. Napa sells a nice complete  kit for it. I remover taking the cam pullies  off and it made it easier. I also welded up a fork to allow me to torquestion them back up.
« Last Edit: Jan 16, 2015, 08:58:20 AM by zippo »
If you see it, its for sale.
4-lo
  • Turtle Points: -80
  • Male Posts: 752
  • Member since Dec '05
  • build tonite crawl tomorrow
« Reply #4 on: Jan 16, 2015, 08:01:49 PM »
Thats got to be 86- pre 93 v6.
On my 95 the tensioner is on the side
4-lo
  • Male Posts: 752
« Reply #5 on: Jan 16, 2015, 08:07:14 PM »
You'll get the hang of it after this built :biggthumpup:. I did after 2 total tear down on mine and one on my cousins.
hey you maybe even advance to pro 3.slow  :dunno:.
Glw tear down.
79coyotefrg [OP]
« Reply #6 on: Jan 16, 2015, 11:55:46 PM »
yep, production date is 12-1987.   I really do NOT want to be an expert on this.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #7 on: Jan 17, 2015, 10:24:19 AM »
When I did mine I took off the cam sprockets then it was a piece of cake. I had a problem with one of the cam sprocket bolts, ended up cutting the flange with a die grinder and it came right off.
zidaro
  • Turtle Points: 480
  • Male Posts: 526
  • Member since Oct '02
  • Mo Chi Chu!
« Reply #8 on: Jan 17, 2015, 02:52:21 PM »
i have a spare 3.0 (blown HG of course) if anyone wants to play
would be interested in parting all the accessories if anyone needs something.  It was a good running 1993 engine before HG pop! R150 manual trans
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
79coyotefrg [OP]
« Reply #9 on: Jan 20, 2015, 12:30:01 AM »
we got them off finally. had to build a tool to hold the cam sprockets but they finally broke loose.
jfowens
  • Male Posts: 12
  • Member since Mar '15
« Reply #10 on: Mar 05, 2015, 01:41:20 PM »
its easier if you pull the whole motor and never put it back in.  if your gonna have v8 milage might as well have one!!
Last post Mar 28, 2004, 10:45:00 PM
by 84runner
Last post Dec 11, 2005, 08:56:29 PM
by BLACKDOG
Last post Apr 16, 2024, 07:21:35 AM
by Pappy
Last post Sep 09, 2021, 08:07:06 PM
by emsvitil
Last post Oct 30, 2008, 07:26:05 PM
by THK Matt
