Also got this in the mail from Marlin...Good thing to as I see the 93-95 kits are already out of stock...And yes that is a hello kitty toaster
gonna look sick with the bed bobbed
As long as it makes toast who cares...i wish my cab was that clean... can i suggest sticking the motor and trans in or filling the cab with sandbags or summin before moving spring hangers... motor and trans will add over 200lbs
Noo run it full bodied.
Already has the engine, tranny and tcase installed
Should have replaced the body mounts while you had the cab off. Looking good!
I would definitely call them. There should be ZERO pitting in an area that was machined.
I'm curious as to what your front shackle angle was when you were completely unloaded. I'm trying to fine tune my front hanger location on mine for the RUFs and I'm at neg20 degrees. I have the TG front hanger tacked at 1" forward of the front crossmember.
Had to snap a pitcure of this cool guy driving down the street with his 40" light bar blazing...
Yes call them and get another one, should be NO pitting there and NO rust ANYWHERE... Thats a bummer getting new parts and have them look like that...
Are you considering buying a 10deg rotated adapter?
Started by Project94 Project Research and Build-Ups
Started by elfking « 1 2 » Project Research and Build-Ups
Started by spc mike « 1 2 3 4 5 » Project Research and Build-Ups
Started by bubs Project Research and Build-Ups
Started by Jason E. « 1 2 » Project Research and Build-Ups
