Author Topic: 86 4Runner 2rz swap "Chuyota" 1st build  (Read 37075 times)
Chuyota
  • Male Posts: 108
  • Member since May '14
« on: May 25, 2014, 11:56:15 PM »
My buddy has been in the 4x4 scene for a while now. So the story goes like this.  He convinced us to join him for a ride to Bald Mountain for some 4x4ing. Even though we rolled lol, I fell in love with the fact that you can explore Mother Nature in your truck! Climb things most trucks can't. This isn't my first Toyota truck, during our high school years all us had Lowered Toyota trucks (bagged) I introduce the birth of "Chuyota"  I picked her up for $2,500, she had a bad rod knock.
Chuyota [OP]
  • Male Posts: 108
Donor truck, 98 Tacoma.
We  buddy sold most of the parts before I remembered to take pics.  The truck had "blown head gaskets" so we thought all we needed was head gasket, pressure test and a resurface. . When we took the engine apart we found the cylinder walls filled with rust! The machine shop had to resurface the block in order to get all the pits out of the block.  In the end we had to do a complete rebuild.
zippo
  • Turtle Points: 569
  • Male Posts: 1,554
  • Member since Nov '08
    • oppiz.net
Re: 86 4Runner 2rz swap "Chuyota" 1st build
« Reply #2 on: May 26, 2014, 06:11:36 AM »
That sucks about the rust. It always cost more then you think it will.
If you see it, its for sale.
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
« Reply #3 on: May 26, 2014, 07:33:25 AM »
So you're going to put the 4Runner body on the Tacoma frame and use the Tacoma full wiring harness?
R.DesJardin
Chuyota [OP]
  • Male Posts: 108
No, Tacoma items are going to be installed on the 4Runner.
Engine is out, now it's time to install the bell housing from the Tacoma on the 4Runner
Sold all the 22re harness and engine.
The goal is to make the Tacoma dash work on the 4runner.
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« Reply #5 on: May 26, 2014, 08:37:42 AM »
killer progress ,  and yes that dash will work with minor modification
Chuyota [OP]
  • Male Posts: 108
Awesome !
I got my old man to give us a hand.
He removed the shock and engine mounts.
Now we just have clean up them up.
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
« Reply #7 on: May 26, 2014, 10:10:24 AM »
 :popcorn:
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • Member since Mar '13
  • @nationallmotors
    • Buy me a soda
« Reply #8 on: May 26, 2014, 01:37:17 PM »
 :flamer:
Chuyota [OP]
  • Male Posts: 108
Went to Pick A Part and found these bad boys today. 1/2 price!!
For some onboard air.  The Volvo only had 80,000 miles.  Now I have to figure out how to mount and use it.
94 4Runner gill, lights, and tilt steering column.
HogCanyonHopper
  • Male Posts: 1,224
« Reply #10 on: May 27, 2014, 09:26:51 AM »
score!!!   :clap2:
Chuyota [OP]
  • Male Posts: 108
Front hanger is in. We cut and welded a receiver.
We used the old 22re engine mount brackets, just cut the inside out. Seem to work well. Motor is level.
Nation
  • Male Posts: 1,565
  • @nationallmotors
    • Buy me a soda
« Reply #12 on: May 27, 2014, 04:40:05 PM »
Interested to see how you run that york. Lookin good man!
old runner
  • Turtle Points: -13
  • Member since Apr '13
« Reply #13 on: May 27, 2014, 06:50:21 PM »
Looking great. Definitely post up some pix of the dash details and mounting the York.
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #14 on: May 28, 2014, 08:44:39 AM »
Welds look awesome.
Just curious how was your shackle angle? I know it will settle.
81 Toyota Trekker 221:1
chim
  • Turtle Points: 1254
  • Male Posts: 1,258
  • Member since Apr '05
  • www.infowars.com
« Reply #15 on: May 28, 2014, 09:52:40 AM »
Looks good so far!
Chuyota [OP]
  • Male Posts: 108
Got me a transfer case.
Now I debating on what Tcase adapter is better.
Chuyota [OP]
  • Male Posts: 108
Any ideas??
Chuyota [OP]
  • Male Posts: 108
Welding on some homemade  frame reinforcement
Cut some holes and getting chewed out for working on the rig to much, I am sure we all can relate:)
Cut out the section so you can still see the serial numbers.
 A little paint.
floorrunner
  • Turtle Points: 333
  • Male Posts: 304
  • Member since Jun '09
  • Common sense is not that common...
    • Buy me a soda
« Reply #19 on: Jun 11, 2014, 12:24:17 PM »
Here is the start of the York to 2rz mount, going to drive this off the alternator pulley so we can still use air conditioning from the factory 2rz compressor.
Started by welding a 22re Ac tensioner pulley to the end of the alternator pulley. Once the bearing is removed from the Ac pulley the socket will go through and you can tighten the alternator pulley to the alternator.
87 4runner, 97 3RZ, dual ultimates, 5.29's air over elocker & arb, true longs R.I.P., York belt driven onboard air and a/c.
floorrunner
  • Male Posts: 304
    • Buy me a soda
« Reply #20 on: Jun 11, 2014, 12:30:18 PM »
Next is to make the mounting brackets, one sits behind the power steering bracket the other two are for the York, one will be a tensioner. This is going to be very similar to Marlin's York mount.
Nation
  • Male Posts: 1,565
  • @nationallmotors
    • Buy me a soda
« Reply #21 on: Jun 12, 2014, 12:26:39 PM »
Very cool
Chuyota [OP]
  • Male Posts: 108
« Reply #22 on: Jun 13, 2014, 06:16:51 PM »
Some goodies came in!!
P/S cooler for power steering.
MC Tcase rotated adaptor, TG shock hoops and 4.70 MC competition chromoly gear kit.
« Last Edit: Jun 13, 2014, 11:33:03 PM by Chuyota »
Chuyota [OP]
  • Male Posts: 108
« Reply #23 on: Jun 15, 2014, 12:27:38 PM »
Dash is in, we managed to keep the 86 HVAC unit. Cut and welded the support brackets off the 86 onto the taco dash support bracket.
Extended passenger side  tail light and fuel pump harness. We kept the factory 4runner  tank and pump.
Disassembled donor Tcase and prepared it for new gears.
She's ready!!
Removed transmission- time to clean years of dirt and oil!!
Prepping for adaptor
Ready for install
Chuyota [OP]
  • Male Posts: 108
Ready for install.
Installed gear box.
Finished reinforcing the driver side.
Next is shock hoops. Which I need to trim, to long.
After installing the transmission, I am really considering a "flat belly" much of the forums say its worth it.  Now it's time to wait for some more parts.
Duodenum
  • Member since Oct '13
« Reply #25 on: Jun 18, 2014, 12:45:40 PM »
What paint did you use on the tranny and tcase? Looks good!
floorrunner
  • Male Posts: 304
    • Buy me a soda
« Reply #26 on: Jun 18, 2014, 09:35:40 PM »
Autozone spray-on Bed liner paint. Nice textured look
http://www.amazon.com/Rust-Oleum-248914-Automotive-15-Ounce-Coating/dp/B003CT49B2
Chuyota [OP]
  • Male Posts: 108
For some reason the shock hoops are to long for my truck.  Maybe cause it was a straight axle to begin with..? Frame seems to set higher than a IFS. I had to cut 2- 1/2 inches. I couldn't cut my wheel well, all of my Evap and  fuse box are setting on top.
Time to add brackets to the Tcase support cut out.
Added a lil protection to the rear diff.
Since I couldn't get the lift I wanted with the 63" Chevy leaf springs I had to bite the bullet and buy  5" TG leaf springs. Luckily I found some used ones for a good deal.
I CANT WAIT TO TAKE MY BABY OUT FOR A RIDE!!!!!!!!
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #28 on: Jun 25, 2014, 10:55:57 PM »
Nice work!
Chuyota [OP]
  • Male Posts: 108
Nice work!
Thanks. Lots of hard work!!
Last post Jul 22, 2008, 04:04:36 PM
by 89toy
Last post May 16, 2013, 11:04:30 PM
by 88_YotaCrawler_88
Last post Nov 28, 2010, 07:14:57 PM
by IVrunner
Last post Dec 14, 2013, 09:26:53 PM
by swilson
Last post Feb 18, 2015, 04:31:56 PM
by yotadork83
