Author Topic: Project fancy-- Nearly finished.  (Read 14667 times)
patches
  • Male Posts: 144
  • Member since Nov '09
  • This guy needs a beer
« on: Feb 19, 2014, 10:03:23 PM »
Well, i broke down and bought a 81' 4x4 for $800.  The donor engine had yet to be installed and was out of an 81 celica. (22r)  Since i had no proof of the condition of the engine it has been completely torn apart.  We found the engine to had virtually no wear; the factory pistons still had all the machine marks and other minor things were in great shape.  Found the #4 cylinder to have the spark plug only threaded halfway in but there was plenty of carbon buildup like someone had been driving it that way.
Long story short pretty much fully rebuilt engine and axles. Waiting to install the noise maker.
Plans for the project are as stock as possible with some fancy things here and there to enhance the pickup functionality wise.
« Last Edit: May 26, 2020, 02:16:14 PM by patches »
I don't trust anything that bleeds for 5 days and doesn't die....
patches [OP]
  • Male Posts: 144
Re: Patches Project fancy
« Reply #1 on: Feb 19, 2014, 10:08:35 PM »
more pics of craigslist post pics when i bought it
patches [OP]
  • Male Posts: 144
« Reply #2 on: Feb 19, 2014, 10:26:59 PM »
engine
patches [OP]
  • Male Posts: 144
« Reply #3 on: Feb 19, 2014, 10:29:32 PM »
I had gotten pretty lucky with this engine in such great shape but still decided to have a valve job done, head resurfaced, and block decked 10thou.  Everything but the pistons, cam and crank were new put into the engine.
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« Reply #4 on: Feb 20, 2014, 08:12:34 AM »
always loved your attention to detail
« Last Edit: Mar 10, 2014, 09:38:40 AM by tgmaul88 »
patches [OP]
  • Male Posts: 144
« Reply #5 on: Mar 09, 2014, 08:48:06 PM »
Well, it runs pretty good now.  Didnt imagine being able to drive it this weekend but i can!  Followed a lot of the smog delete stuff from this guy http://www.yotatech.com/f114/22r-desmog-tutorial-264405/
I have some buttoning up to do in the interior, engine bay, and figure out what to do for steering.
patches [OP]
  • Male Posts: 144
So here is how it sits today,  W56. Duals. RUF and 63's.  4.88's and bald 37-14.5-15 tires.  Put a 3rz Dual Ignition Coil engine into it that ended up being bad.  I have found a distributed engine but am wondering what it entails to convert from distributed to DIC.  The harness/computer i have is for a DIC 3rz and the engine i can get is a distributed 3RZ.
And i fit a 99 ish taco column and dash into it.
« Last Edit: Jan 02, 2016, 05:24:07 PM by patches »
patches [OP]
  • Male Posts: 144
Few more.
patches [OP]
  • Male Posts: 144
Heres the first flex pics with 10''  front shocks and i realized i needed to trim my front shackle body mount because the shackle was getting bound on it.
Had to flex on the roomates heep  :)
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
Don't take it to the bank, but I believe all you'll need to do to make a dizzy engine a dual coil is swap the harness and associated sensors.
01 double cab hunting truck
06 tacoma street truck
patches [OP]
  • Male Posts: 144
But which sensors.....
redneckcustoms13
  • Male Posts: 2,513
Any of them that are different. I wouldn't imagine there are many of any that are different. I can verify this in a few days if you like. My 98 taco is a 2 coil and the 1st gen in running a dizzy.
patches [OP]
  • Male Posts: 144
Yea that would be nice I only have access to the distributed engine right now
redneckcustoms13
  • Male Posts: 2,513
Ten 4, give me till about Wednesday and I'll look at them side by side. Won't be around the taco till then.
patches [OP]
  • Male Posts: 144
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
I've done quite a bit of mismatching different years of 3rz. I could prob tell you what I might do. what happen to the cop motor? block or head damage?
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
redneckcustoms13
  • Male Posts: 2,513
Looks to me that you can just swap the cop harness to the dizzy engine and remove the dizzy. Both have cam position sensors, injector harness looks the same, oil pressure looks the same. Maybe crunchy can tune in on something I'm missing. Looks like a straight forward swap. I could be wrong.
Crunchy Taco
  • Turtle Points: 90
should be able to use the cop harness and cap the dizzy. the only thing you will have to run on the dizzy motor from the cop is the cop throttle body with the iac valve. I believe they're different.
Crunchy Taco
  • Turtle Points: 90
the only other thing would be check the crank and cam position sensors and make sure they have the same number of wires on both motors but I believe the same type of sensors were used pre 2001
redneckcustoms13
  • Male Posts: 2,513
Your correct on the iac. I'm sorry I mislead on that. I forgot the iac got changed after dizzy motors.  :hammer:
patches [OP]
  • Male Posts: 144
The original engine got ran dry of oil and seized really bad,  What my truck is set up for right now is the dual ignition coils not coil on plug, so would that mean I still need to mess with IAC valve?
redneckcustoms13
  • Male Posts: 2,513
I believe the dizzy engines and dual coil use the same. The cop uses another.
Crunchy Taco
  • Turtle Points: 90
I tried using a 2004 cop throttle body and iac on a 99 dual coil setup and I had idleing problems. I'm not sure if it was the 99 ecm not jiving with it or the way it draws air in for idle. most dual coil years have a breather tube that connects the iac to the air intake pre throttle body but the 01-04 cop iac dosnt have that tube so It gets air another way. as far as the dizzy and dual coil years I used to have both both motor combinations and I remember the iac valves had a different number or wires on the plug. I believe the dizzy iac has 4 and the dual coil iac has 3 wires. whether you can check wiring schematics and figure out what wire does what and still use the dizzy iac for your dual coil wiring and ecm is up to you to figure out I suppose. you may be able to delete one of the 4 wires in order to run the iac on the dual coil depending on what the purpose of the 4th wire is on earlier years.
Crunchy Taco
  • Turtle Points: 90
I apologize for gettin confused earlier in the topic. for some reason I thought you were messin with a quad coil on plug motor. I kno now that your are setup for a dual coil and trying to use s dizzy motor. the easiest way to do things if it were me would be to put you dual coil throttle body on the dizzy motor, coil brackets to hang your ignition coils, cap the distributor, and you should be turn key. they both should have the same egr setups. everything else should be the same.
patches [OP]
  • Male Posts: 144
Thanks for the reply guys!  Currently i'm still in limbo with getting the engine.
Crunchy Taco
  • Turtle Points: 90
updates? had any time to figure out your problem?
patches [OP]
  • Male Posts: 144
So I got a 2rz long block and stuffed it all in there with a w-56 and dual cases! Tacoma dash is fairly done.
patches [OP]
  • Male Posts: 144
patches [OP]
  • Male Posts: 144
Everything's not entirely buttoned up yet.
patches [OP]
  • Male Posts: 144
Re: Project fancy---Updates
« Reply #29 on: May 26, 2020, 02:09:50 PM »
Fast forward a couple years and here are the current additions
Front axle:
+8” diamond front housing —- Full width spring perches
Marlin 25mm steering kit
Fzj80 hi-pinion front diff 4:10’s w/ ARB
Rcv 300m shafts
Long field studless hub kit
TG 6 shooter knuckles
Tg chromolly spindles
Rear axle:
Tacoma rear welded w/ 4:10
Suspension:
Radflo 2.5” 14 remote resi shocks all corners
Radflo 2” x 2 bumpstops front
Fox 2” x 3” bumpstops rear
Sky‘s 3f front springs
Sky‘s 4” rear springs
Sky’s front full width spring hanger kit
Sky’s rear spring hanger kit
Raceline 17x9.5 beadlocks
Interco sxii 37x12x17
Last post Oct 06, 2005, 08:11:08 AM
by sloyota
Last post May 08, 2008, 08:37:26 PM
by IVrunner
Last post May 02, 2009, 05:23:30 PM
by thegoofster21
Last post Mar 19, 2009, 08:39:56 PM
by IrieKidinCal
Last post Apr 25, 2013, 09:45:59 PM
by kneedownnate
