Author Topic: 98 Boosted short tacoma (3rz turbo)  (Read 112668 times)
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
Re: 98 short tacoma ( the build goes on )
« Reply #60 on: Feb 18, 2014, 05:21:35 PM »
Got started rebuilding my bed need to pick up some steel
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #61 on: Feb 18, 2014, 05:35:54 PM »
Don't freak out I just started I promise there's a reason for everything I've done. I think. The pictures suck ill take some more when I get some good work done and it looks like something awsome
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #62 on: Feb 19, 2014, 06:22:13 AM »
Now that I moved my rear back 4 in. The wheel cut outs don't line up I gotta work on that
camhays556
  • Turtle Points: 498
  • Member since Nov '12
« Reply #63 on: Feb 19, 2014, 03:21:57 PM »
nice fab work, lookin good  :beer:
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #64 on: Feb 19, 2014, 04:37:35 PM »
Thanks I give er my best
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #65 on: Feb 19, 2014, 04:43:50 PM »
I can't remember where I saw this but I thought it was awsome so I did it. Sick of those things slappin around. Plus they hit my shackles now that I moved the rear end back. I had to build a new drive line for the back too.  It's 4 inches longer I tried to copy the one I had exact weights and all.  I just slid a new piece of tube on to the yokes and took 500 measurements off a straight edge. Thin wall pipe works the best cause less weight to be off balance but its not as strong
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #66 on: Feb 19, 2014, 04:47:00 PM »
A better one
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #67 on: Feb 20, 2014, 08:57:39 PM »
I put the side tubes in and the rear mounts. The front tube bends arnt guna work with how I'm guna do the wheel wells so I have change it. I have an idea of what I'm guna do
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #68 on: Feb 22, 2014, 08:05:24 PM »
Got more done on the bed.  Changed the front brackets and part of the floor frame.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #69 on: Feb 23, 2014, 11:33:25 AM »
Here's the new stance with bed back on. The cut outs don't really line up in back now that I moved the rear end back but I think ill just roll with it. My truck looks higher than it is cause the cutouts I did to stuff 39s but now I'm rolling on 35s and its unnecessary ill go back to 39s someday or at least get new front fenders wich I might do for my new 04 front clip that's in the making. Flex test coming soon. And a pic of my cousin trying to work a 04 taco grill into his third gen.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #70 on: Feb 23, 2014, 03:16:03 PM »
heres one of the only pics i can find right now to show where the rear end use to sit...it was too far forward for my likings....i had it that way for alot of years too
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #71 on: Feb 24, 2014, 08:04:38 AM »
here are a couple videos of my 98 3rz powered tacoma with the 99 3rz, i wana compare the power of the 99 3rz to the power of the 04 3rz i rebuilt and hopefully guna swap in this week.....
Crunchy Taco [OP]
  • Turtle Points: 90
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #73 on: Feb 24, 2014, 08:09:31 AM »
ill have to get some better vids up, its super hard to drive and video in a safe manner...you get the idea though
Crunchy Taco [OP]
  • Turtle Points: 90
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #75 on: Feb 24, 2014, 02:40:48 PM »
Got more done on the bed. Just gotta finish weld and patch a few more spots in
« Last Edit: Mar 25, 2014, 09:13:08 AM by TacomaLover »
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #76 on: Feb 25, 2014, 05:33:53 PM »
The bed is pretty much done just gotta flip it over and weld the under side then paint. Everything seems to be workin good with the new rear frame rebuild and axle relocation.
« Last Edit: Mar 25, 2014, 09:13:53 AM by TacomaLover »
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #77 on: Feb 25, 2014, 05:36:16 PM »
X3
« Last Edit: Mar 25, 2014, 09:14:11 AM by TacomaLover »
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #78 on: Feb 26, 2014, 06:37:28 AM »
So yesterday I was welding the last few pieces in the top of the bed and didn't know it but my gas cap was right on the other side touching the area I was gettin red hot. Anyway I had a small fire it burned for 30 sec while I got a bucket of water then I found a fire ex. If it would have got through the gas cap I would have prob went boom got real lucky. So my new advice to everyone is to either keep a fire ex on your welding cart or on yer truck. I think ill do both.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #79 on: Feb 26, 2014, 05:36:46 PM »
Finally finished my bed.  Had a fire but got the sob done
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #80 on: Mar 02, 2014, 09:07:41 AM »
I know nobody cares about this thread but I like it so I'm gonna update it. I made my front hangers. They are up 3 in higher than my old ones that were mounted on the bottom of the frame some day I might make these a little better with cab off cause its super hard to weld up in these tight spaces but I got to it all its just not as good as I usually like to do things. After I designed these I ended up lookin at trail gears Tacoma shackle kit and not even meaning to I kind of resembled the way they did theirs so this must be the way to go. Enjoy
« Last Edit: Mar 02, 2014, 09:13:42 AM by ToyArmy98 »
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #81 on: Mar 02, 2014, 09:11:23 AM »
The only thing I might change is the spacer that goes in between the shackles up inside the bracket, I think it needs to be bigger around to put bushings in.  I'm not sure how its gonna work out with no bushings up in there. I noticed trail gears kit has bushings that go in the upper mount
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #82 on: Mar 02, 2014, 09:12:34 AM »
Couple more
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #83 on: Mar 03, 2014, 06:29:37 AM »
Here's the shackle angle with the motor back in and all the weight on it. I still have to add a leaf to my spring pack I only have 3 leaf pack right now. Once I adjust my spring pack I think the angle will be just the way I like it.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #84 on: Mar 03, 2014, 06:35:26 AM »
New motor picks coming soon. I'm lovin the freshly rebuilt 04 3rz it pulls the hills on the freeway with ease my other motor must have been tired cause holy crap what a difference. Maybe the leaky rings on my othèr motor had something to do with compression loss or something i never did test the compression. And what a smooth running motor. I'm happy with the job I did on this one.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #85 on: Mar 03, 2014, 06:36:36 AM »
Next on the agenda putting my 04 Tacoma front clip on.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #86 on: Mar 04, 2014, 05:58:20 AM »
Ok finally here's a few picks of the new ride height. It's a little lower than I thought it would be but I like it. I need a flat pitman arm now and redo my front bump stops ANSI should be good to go wheel. I don't even really wana flex it until the pitman arm is changed out. The new t100 oil pan gives me more than enough clearance I didn't have to smash it in with s hammer like my Tacoma oil pan for clearance.
« Last Edit: Mar 25, 2014, 09:18:29 AM by TacomaLover »
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #87 on: Mar 04, 2014, 05:59:19 AM »
X2
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #88 on: Mar 04, 2014, 10:24:28 PM »
Here's a better pic its not so dark out
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« Reply #89 on: Mar 04, 2014, 10:29:17 PM »
I love it !!!
Last post Sep 23, 2005, 05:47:52 PM
by wa4x4
Last post Aug 19, 2005, 10:45:58 PM
by 88-REDRYDER
Last post Apr 13, 2007, 12:06:10 AM
by SACD_Runner
Last post Jul 08, 2014, 08:10:31 PM
by ntsqd
Last post Nov 16, 2014, 02:53:39 AM
by cavey
