Well damn! Yes we rebuilt mine with old wheels and did not rebalance it. I've had it up to 30psi no problems. All you need to do is mark the nut to the shaft AND the wheel. Is your compressor wheel the style that has the "integrated nut" machined into it or does it have an actual nut? Remember, it'll be a left handed thread so the turbo can't unwind itself and take extra care not to bend any blades. When I put mine back together I used a dab of red Loctite, you might have to heat the nut up to free it up.Heres an example of average cost http://www.xsboostturbochargers.com/products/td025td03-rebuild-kit-superback-volvo-2-8l-2-9l-twin-turbochargers/ Shouldnt run you over $90 to rebuild it. Also, what size of oil feed line are you running? I believe I'm running -4an without a restrictor.
Oh yeah! Now you're talking! I see that you can set up watermeth injection signal off this thing as well!!! You've gotten me thinking about megasquirt PNP for my 85.... I really want to boost that thing. I scored a TD05 off of a mitsubishi diesel with VGT and I already have a manifold flange from LCE.... tempting....
I mix 5 gallons of w/m at a time now man. I love that stuff. Now my clutch slips when my turbo spools... floppin' thousand bucks for a flywheel and clutch..... On the cheap!
Thanks man, it drives like a dream! Thats running k03's I'd imagine, quick spool for sure but drop pressure after 5200. Mines ramped over 20 psi at 4100....2000 more than stock. My damn phone wont send these other pics to my email to upload on photobucket. Its pissing me off....... Ill try to get some pics uploaded.
I still have the same gauge cluster in my truck from when it had a 3.4.. The rpm have always been off with the 3rz. I'm assuming the calibration is different for the two engines and their tach? Is there anything I can do or do I need to get a cluster from a 4 banger?
Dakota digital makes tach signal adapters. I had to use the SGI8 when I did my diesel swap.
Started by drybone Parts For Sale
Started by Skinny_Pedal Engine
Started by OregonCrawler Toyota Pickup/4Runner Tech 1979-95
Started by ntsqd Rigs For Sale
Started by turbo this.. Engine
