Yes my buddy had the SAFC on his eclipse. They work very well for how inexpensive they are. One thing you may consider down the road, though you arent running much boost, is throwing like a 220 watermeth nozzle on that beast. I have a 550 on my audi and it makes ALOT of difference. After we built the manifold and got the 53mm turbo on there (stock was only 38mm) and going from 12psi to 20psi I was running in the 12.0-12.5 AFR range. Installed the meth and runs solid 11.5-11.7 AFR's, another 5 degrees of timing and way more crisp throttle response. Plus for me the 2.0t fsi direct injection allows the intake valves to carbon up so the watermeth keeps the internals looking shiny clean! Lower IAT's, more timing, cleaner internals, lower EGT's and drops AFR's 1 full point at full spray allowing more boost without fuel cut. Cant go wrong there I have the AEM kit but I've seen people build it for cheap on a budget! Cant beat boost, who doesnt love to listen to a turbo spool???
Little turbo porn for ya!
Elbows: http://www.acestainless.com/butt-weld-fittings/304l-buttweld-fittings/weld-elsFlange: http://store.034motorsport.com/exhaust-manifold-flange-2-0t-fsi-2-0-tfsi-2-0-tsi.htmlT3 Flange: Ebayand a nice TIG machine I have an exhaust flange for 20r/22r/e from LCE with the 1 5/8'' ports sitting on the shelf, tossing around the idea of boosting my runner but I just want to get it going before I tackle another major turbo swap. Plus the old ECU's are VERY limited with what you can do... I had to purchase an $800 interface for the Audi from Maestro to tune it. My turbo is a T3 borg warner GM3 off of a GMC 6.5 diesel I scored for $50 then rebuilt it for $90 and custom shaved the housings and custom drilled surge ports in the compressor side. Needless to say it whistles LOUD Guys want around $1200 for my style of manifold and we built it for less than $500.Now enough of the high jacking.TacomaLover, how are you with a TIG welder?
My favorite so far is the volvo td05-12b with the atmosphere BOV built in. I'm getting another one today with a different style exhaust side for better flow out of the wastegate. These turbos are all too small and create alit of heat so eventually wana run something bigger but for now these are ok to play with!
If I was going to buy a kit I would get the kit from KO racing its about 2400 Theresa ton of different options for turbos and other parts when you personalize your kit. Someday that's the kit I want bad. They are made to bolt on and run 4.5-5psi no aftermarket management.
Started by drybone Parts For Sale
Started by Skinny_Pedal Engine
Started by OregonCrawler Toyota Pickup/4Runner Tech 1979-95
Started by ntsqd Rigs For Sale
Started by turbo this.. Engine
