Author Topic: Drive line vibration, what to do?  (Read 2121 times)
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« on: Nov 05, 2013, 10:50:52 AM »
My buddy lifted his cherokee 4 inches. Now has a drive line vibration. Guess we have to lower the trans to compensate for the ds angle?
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: Drive line vibration, what to do?
« Reply #1 on: Nov 05, 2013, 03:13:46 PM »
Is the rear pinion angled up towards the t-case output?  And does it still have the slip yoke output on the t-case?
hilux-1983 [OP]
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #2 on: Nov 06, 2013, 11:35:55 AM »
Yes and yes(it's about an inch out of the output though)
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
« Reply #3 on: Nov 06, 2013, 01:59:34 PM »
you need a dl with a double cardan joint
merace19
  • Member since Nov '13
« Reply #4 on: Nov 07, 2013, 05:49:15 AM »
There is a spacer kit for the cherokee to lower the transmission some.  But getting the angle of the rear pinion 2 degrees less than the output of the trans is the best set up.  You should not need to do a SYE with a Cherokee cause the drive shaft is way longer than a TJ. And I had at least 5 jeeps with 4 inch lift with no issues as long as the pinon angles are set right..
I am a Jeep nut and just got a 4runner to mess with.
merace19
« Reply #5 on: Nov 08, 2013, 04:23:35 AM »
can you post a picture of the drive shaft and pinion angle? You have a angle finder? They are like 5 bucks at Home depot
Last post Jan 30, 2005, 08:04:29 AM
by moutaintoys
Last post Feb 11, 2005, 11:14:44 PM
by Hyena
Last post Apr 18, 2005, 12:05:39 PM
by tdawg
Last post Nov 27, 2005, 01:51:07 PM
by yodersgirl
Last post Jan 11, 2007, 08:13:31 AM
by FIREBALL
