Author Topic: stuck differential plug  (Read 1106 times)
donutslayer
  • Member since Sep '13
« on: Sep 19, 2013, 02:43:20 PM »
I am not sure if this goes here in this part of the forum or in the differential section since this could apply to multiple areas. I have a stuck differential filler plug. Normally if I was just an ordinary stuck bolt I would douse it in a little penetrating oil then a bit later get after it with a torch. However I am a little concerned to hit the plug with heat. Any suggestions here?
  • Turtle Points: 458
  • Male Posts: 3,440
  • I'LL NEVER MAKE IT...
Re: stuck differential plug
« Reply #1 on: Sep 19, 2013, 02:50:43 PM »
Worst ones in the past I have welded a piece of rod to as a breaker bar, then you can usually get them out no problem. It gives you the heat and something to grab it with all in one motion.
I would rather wake up in the middle of nowhere than in any city on earth.
Steve McQueen
donutslayer [OP]
« Reply #2 on: Sep 19, 2013, 02:58:54 PM »
I definitely never thought of that one. Unfortunately I do not have a welded I wonder if I  could epoxy a rod to it. I guess I could always take it down to the local weld shop
  • Male Posts: 3,440
« Reply #3 on: Sep 19, 2013, 07:05:18 PM »
I'll bet a liberal amount of JB weld would work as long as you make some grinder marks for it to bond to.  I would probably heat it up too.  It would be fun to see if it works anyway...
Rod stock, an old wrench, whatever seems to fit the occaision.
Steve McQueen
locked 4x4
  • Male Posts: 468
  • Member since Aug '09
« Reply #4 on: Sep 19, 2013, 07:44:07 PM »
id go for the welding shop
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,049
  • Member since Aug '07
  • Heyo
« Reply #5 on: Sep 19, 2013, 07:47:41 PM »
Don't put them in so tight...
Is it stripped? Use a cheater bar or pipe wrench.
You'll never take me alive
donutslayer [OP]
« Reply #6 on: Sep 23, 2013, 06:28:44 PM »
Thank you for your help, it finally came off after hitting it with the torch and PB Blaster.
  • Turtle Points: 1340
  • Male Posts: 17,784
  • Member since Apr '02
  • 511:1 Club
« Reply #7 on: Sep 23, 2013, 07:55:53 PM »
Another trick could be to use a Dremel to cut a ridge into the side of the plug facing the counter clockwise direction, and use a hammer and a flat head screw driver or dull chisel on this ridge to hammer and slowly rotate the plug out.
Mike
New Instagram: @SlowestTacoma
2016 56-speed 580:1 Triple T/Case 3rd gen Tacoma Rock Crawler
Error occurred because of error.
mudmaster
  • Turtle Points: 1951
  • Male Posts: 2,596
« Reply #8 on: Sep 24, 2013, 11:09:34 AM »
I've used an air chisel.........
Time to go wheelin!
Last post Nov 14, 2005, 07:50:55 PM
by MidgetMike
Last post Jun 08, 2006, 06:44:40 PM
by Plowking
Last post May 28, 2007, 12:55:28 PM
by DTB
Last post Mar 17, 2009, 10:33:05 AM
by Wermz84
Last post Sep 11, 2011, 02:28:47 AM
by Rocksurfer
