The perches will line up but there are two different widths. Measure your springs and measure the perches on the axle you are getting. You may have to replace them anyway depending on your D-line angle.
You will also need the brake lines and e-brake cables since the axle is wider.
You will have better braking since the IFS Axles have bigger brakes in the rear.
