if you want the 58" IFS front width... here is what my buddy did on his 81 front axle he is using for rear steer on his 78 Toy.FJ60 Rotors (I got 1981-1985 FJ60 Land Cruiser Premium Rotors from Napa, Part Number # 4885799 $31.99)V6 CalipersIFS Hubs(4) 2"x0.5" Grabe 8 Bolts w/ LocknutsWe used a 1/2" Drill bit to drill out the ears on the Knuckles & the mounts on the CalipersThen drilled out the holes on the Rotor so it could be bolted down to the IFS Hub.You must very carefully remove material from the mounting surface on the calipers.... til the rotor sits inside correctly as it will be slightly off.taking very little material off the caliper ears.... is much easier and safer then the mounting ears on the knuckle.Be careful you can take too much off the caliper.All the spacing is correct and no spacers or "conversion" parts needed.the hub bodies from SFA and IFS are EXACTLY the same dimensions... the flange is just cast on 1.5in out on the IFS Hub.No need to by Spacers or Sky's Conv.I drilled 4 new holes and enlongated the two OEM bolt holes.....my buddy's reasoning.... 6 strong holes... rather then drill all 6 new holes and have 2 weak ones by having soo many holes all right by each other.
dude...i didnt get it either. it makes a bunch of sense now though. caliper sits on the other side of mounting ears and you redrill the rotor to match the samller 6 bolt pattern that the IFS hubs use. then use SA lockouts and its legitimified.
Started by Jimmyg Engine
Started by Barfot Toyota Pickup/4Runner Tech 1979-95
Started by chevihemi Parts For Sale
Started by Jakesteads Parts For Sale
Started by rockymtn89 Parts For Sale
