Author Topic: Spring Mounts SAS T100  (Read 4703 times)
541mudder
  • Turtle Points: -22
  • Member since Apr '13
  • rock crawlin, huntin, campin, drinkin...nuf said
« on: Aug 02, 2013, 07:29:40 AM »
I have been working on gathering all the necessary parts required to do an SAS. I have found 2 different spring mounts that have both been used on T100's. I am partial to the one that reinforces the frame but I am having difficulty drawing the parts out so I can burn them out of plate. The other option is far easier but I don't like the look of it as much. my question is what do you guys think and what are pros and cons of each system?
Thanks.
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
Re: Spring Mounts SAS T100
« Reply #1 on: Aug 02, 2013, 07:47:48 AM »
nice rig man. btw, just to give you a heads up  :psss:, flip off pictures are not allowed on the Marlin forum.
541mudder [OP]
« Reply #2 on: Aug 02, 2013, 11:46:47 AM »
OOOOOPS... Hopefully they will forgive me. These Vehicles are not mine... I found the picture on the web and only posted them to show what the spring mounts that I am referring to look like. Thanks for the heads up on the picture.
« Last Edit: Sep 11, 2013, 07:31:55 AM by 541mudder »
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • Member since Jun '07
  • i think i'm cool
541mudder [OP]
« Reply #4 on: Aug 02, 2013, 02:15:13 PM »
I have seen this build before... I have done a lot of research and have read every forum I could find on a T100 SAS. I am just trying to get peoples opinion on why one system is better than another. Thanks for sharing tho.
« Last Edit: Aug 02, 2013, 03:12:47 PM by 541mudder »
Toydanota
  • Turtle Points: 421
« Reply #5 on: Aug 02, 2013, 07:40:46 PM »
I know that sky manufacturing  just released some sas stuff for t-100s. Worth a look.
541mudder [OP]
« Reply #6 on: Aug 05, 2013, 07:15:02 AM »
That's sweet... someone finally made a kit. I am still going to build my own just because I can and its cheaper. Which style of mounts do you guys like better? (from the picture above)
541mudder [OP]
« Reply #7 on: Aug 19, 2013, 04:22:15 PM »
Come on guys share your opinions... I'm hitting a wall here  :hammerhead:... not sure which method to go with.
J-Rod
  • Member since Sep '09
« Reply #8 on: Aug 19, 2013, 05:31:16 PM »
Sounds great Toyin. Make sure you brace the frame and plate the frame for the steering box. you can get away for a long time with out it but the frame will start to crack around the bolts. i just did it this passed yr with only a miner hair line crack
Yes the front axle has well over 100k and i have not had any issue with it.
So sounds like plating is a good idea, ;)
« Last Edit: Aug 19, 2013, 07:08:56 PM by J-Rod »
541mudder [OP]
« Reply #9 on: Aug 20, 2013, 07:07:00 AM »
With that information I am far more tempted to go with the plated version. Thanks
Last post Dec 31, 2007, 09:40:59 AM
by dyogim
Last post Aug 17, 2009, 02:44:31 PM
by 4Runtoy
Last post Oct 05, 2016, 03:47:10 PM
by Smithk2ski
Last post Aug 02, 2013, 02:26:12 PM
by 541mudder
Last post Jun 24, 2013, 07:14:33 AM
by 541mudder
