Author Topic: Sorry for another failed cali smog but my numbers are pretty high plz help  (Read 2818 times)
eskimo19
  • Turtle Points: -2
  • Male Posts: 18
  • Member since Apr '12
  • Nor Cal
86 4runner Sr5 22re 5 speed stock failed cali smog fresh oil change guaranteed to pass stuff and air filter
I have a #5 stored code im guessing o2 sensor since the truck came from a no smog area and im sure none of that has been replaced. The truck seemed to run fine thats why i took it in but smog tech said my timing was at 15 and that was it. I am going to be doing plugs cap, rotor, clean egr, valve adjustment, fix the timing. any help would be appreciated if you think i should add something else. Just a broke Airman so dont have alot of money to be throwing around.
           -----CO2---O2---HC-MAX----AVE----MEAS----CO-MAX----AVE----MEAS----NO-MAX----AVE----MEAS
15mph----14.2---0.6-------131--------60----148----0.61---------0.08----0.48-------1085-----285-----1848
25mph----14.2---0.4-------103--------44----135----0.77---------0.10----0.51-------1120-----289-----1902
86 4Runner Sr5  stock and looking to change that soon.
jl93221
  • Member since Apr '08
new catalytic converter can make a big difference, how old is yours?
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Get a cheap cat they go bad fast if someone ran cheap gas in it
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
My guess is that cat is original, the guy i bought it from didnt mention to much he only towed it behind a motor home. had to replace the timing chain gasket because it was puking oil but it looked like someone was working on it before. Im thinking of getting an LC engineering cat any thoughts on their cats?
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Timing needs to be 5 degrees +- 3
I get best results at 2.5 - 3 degrees BTDC
High NOX can sometimes be fixed by adding backpressure.    I add a plate after the cat to do this.
http://board.marlincrawler.com/index.php?topic=64908.msg798411#msg798411
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
did you make that plate??
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Yes, it's just sheet metal.
Installed after the cat  (only during smog tests)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
With the timing that far off, it would be hard to say what the cause is.  Do the tune-up, maybe pull the cat to see what it looks like(should be able to see blurry light through the other end), then do another pretest to get an idea of where it is at at stock settings.
$300 for an LC engineering cat isn't worth the money, just buy one from a local auto parts store.
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
thanks for the all the advice and ill go ahead and do all that stuff and see where it leaves me.
Vang530
  • Member since May '12
get yourself a $10 timing light at harbor freight and get it back close to spec (5 when jumping the correct jumpers)..15 degrees is way too much!
Oroville, CA
jl93221
whatever cat you decide to buy make sure it has a carb number stamped on it
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
ok took it back in today and still failed i did cap rotor plugs wires adjusted timing to 5 BTDC been running injector cleaner ever tank checked for vacuum leaks has new air filter cleaned egr and its working replaced o2 sensor with denso one and dont have any stored codes. drove it 40 miles on freeway prior to test and left running for 5 min before they took it in. would a new cat pass me with these number?
thanks :wall:http://board.marlincrawler.com/Smileys/marlin/wall.gif
                 o2          HC                                      CO                                                 NO
                               max       ave      meas          max           ave          meas            max          ave            meas
15 MPH      .7           131         60       144            .61            .08             .48              1085         285           964
25 MPH      .4           103          44       137            .77            .10            .58                1120        289           1288
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
You mentioned that you think the cat is original.
How many miles on the truck?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
279,xxx on the clock and the cat has been welded from the down pipe so either it was replaced a long time ago or who knows but looks older.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
                 o2          HC                                      CO                                                 NO
In 2007 my numbers were
15mph     1.2 o2    max 146 ave 43 meas 119     max 1.04 ave .16  meas .07    max 1136 ave 406 meas 769
25mph      0.9        max 118 ave 32 meas 87      max 1.32 ave .15  meas .09     max 1222 ave 349 meas 1176
just squeaked thru
Put a new cat on for 2009
                HC             CO          NO
15mph    meas 15  meas 0.00 meas 325
25mph    meas 14   meas 0.00 meas 88
So I think a new cat will solve the problem
Also note the 2009 measurements were with the backpressure gasket in place
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Snowtoy
  • Male Posts: 2,583
Could be the cat, your HC's are on the high side.  Have you checked for intake/exhaust leaks?
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
slight exhaust leak coming from the weld seems on the muffler not bad and thats after the cat and i found a crack on the intake tube connecting to the intake. im not sure if its sucking air from there and if it is would that really throw my numbers that high?
thank you for all the replies i will be replacing the cat soon. found a magnaflow cat thats cali legal for 250
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
250, that seems high............
(but I have no idea what they cost now..........)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
those $100 cats aren't CA smog legal...... they are 49 state, except CA legal..... they have a note on them that says not for sale or use in ca on a pollution controlled vehicle
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
I thought the CA versions were closer to $150.
I saw a universal no-name brand at rockauto for just over $100 that was CA legal...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
i know it needs the cali carb stamp, would the rock auto one work?
eskimo19 [OP]
  • Turtle Points: -2
  • Male Posts: 18
  • Nor Cal
well found that my cat was completely hollowed out, nothing left so got the new one on and we will see tomorrow. thanks for all the help
Last post Mar 22, 2007, 05:37:42 PM
by fatt_matt
Last post Jul 25, 2007, 11:34:41 AM
by emsvitil
Last post Mar 08, 2010, 11:33:10 AM
by Plekto
Last post May 26, 2012, 09:49:49 AM
by 87toyotaman
Last post Dec 04, 2014, 07:43:24 AM
by 1985CRAWLER
