Author Topic: Shackle Bolts  (Read 2289 times)
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Shackle Bolts
« on: Jun 10, 2013, 03:30:45 PM »
Do you have a problem with your shackle bolts coming loose. I learned this trick from Roger Brown (4crawler). Weld tabs to the shackle, that the bolt head will slide done to keep the bolts  from turning. They have not come loose since I did this.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: Shackle Bolts
« Reply #1 on: Jun 10, 2013, 03:53:17 PM »
Good idea. Ill try that next. Had to drill my bolt and put a cotter pin in.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
Re: Shackle Bolts
« Reply #2 on: Jun 10, 2013, 03:57:37 PM »
Pretty good idea, if mine ever come loose I'll use it.
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
Re: Shackle Bolts
« Reply #3 on: Jun 10, 2013, 05:26:31 PM »
Around here this is known as the CruzrDave Shackle Fix.
Been running em since 2004. Technically we only need one piece per bolt to prevent it from rotating, two are overkill I'd say. So when I changed the length of my front shackles, I only welded on just one.
No more fighting those bolts!!
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
Re: Shackle Bolts
« Reply #4 on: Jun 10, 2013, 07:25:57 PM »
 :thumbs: nice. I was fussing with my shackle bolts last weekend on the trail. I'm going to try this and see how it works.
  • Administrator
  • 511:1 Club
Re: Shackle Bolts
« Reply #5 on: Jun 11, 2013, 07:23:08 AM »
If possible I'd suggest running this top and bottom. So in general, you only need two small flat pieces per shackle assembly (8 for the entire truck): One piece to stop the upper bolt from rotating and one piece for the lower bolt. I do this because I've had both upper & lower nuts come loose.
In actual fact this is nothing too special, it's just that the generic shackle design on the market does not use a pressed fit shackle bolt like the original Toyota shackles. So what this trick is doing is it is fixing the bolt with the shackle plate so that the bolt always rotates with the plate (as originally intended by Toyota). Once the bolt is fixed with the plates, the nut will also be fixed to the bolt as well as the opposing shackle plate and won't be able to slowly work its way off.
You could also do this for free with a welder at the expense of a crude finish: Remove the bolt and lay a bead of weld tangent to each shackle bolt hole (of only one side of only one plate per shackle assembly). Then use a grinder and neatly finish with a flat file to manipulate the weld bead into a nice flat edge that rides up against one of the six sides of the shackle bolt. Done!
Another nice thing about this is when you are checking torque or servicing your shackles, you don't need to hold two wrenches anymore. With the bolt fixed in place, you can just loosen/tighten the nut using only one wrench.
Last post Apr 04, 2005, 08:16:06 PM
by 86 4runner
Last post Nov 28, 2005, 01:43:51 AM
by wa4x4
Last post Jun 01, 2008, 08:56:19 PM
by Tallchevy
Last post Sep 30, 2010, 08:02:50 PM
by yotatough
