Author Topic: 86 XtraCab... Removing rear interior pieces...  (Read 1425 times)
emsvitil
  • Online Silver Turtle Award
  • Turtle Points: 5228
  • Male Posts: 3,281
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« on: Apr 11, 2013, 10:16:54 PM »
I've looked at this and can't quite figure out how to remove the rear panels below and around the rear and rear side windows without destroying them.....
Carpet is easy, door panels are easy, front kick panels are easy.
I need to weld down the seat mounts (broken spot welds) that the seat brackets are attached to, and figured while I have the seats and carpeting out, I'd add some sound/heat insulation under the carpet and behind those rear panels; plus add speaker wiring for the rear speakers I'll eventually install.  (and fix the stretchy cord for the mesh pockets on the back panel)
Pictures would really really be great......
Thanks
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil [OP]
  • Male Posts: 3,281
    • emsvitil's album
    • Buy me a soda
Re: 86 XtraCab... Removing rear interior pieces...
« Reply #1 on: Apr 12, 2013, 01:42:43 PM »
Nobody has ever successfully removed the rear panels...............
 :smack:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil [OP]
  • Male Posts: 3,281
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Apr 12, 2013, 07:47:48 PM »
I quess I'll answer my own question...........
Rear panel (with mesh holders):
1. Remove rear package tray.
2. Remove rear carpeting.
3. Your going to sacrifice the 4 plastic pop rivets up top......
4. Start at top corner and pull (sacrificing the pop rivets) until they either break apart or come out.  This also will pull it out from under rear window rubber.
5.  There are 3 strips of glue holding it on.   2 horizontal on either side in middle, and 1 vertical dead center.   You reach your hand behind it until the glue lets go.
Rear plastic side panels around/below rear windows:
1.  Remove rear panel (see above)
2.  Remove seat belt and package tray brackets from sides
3.  Remove windlace from rear of door opening
4.  Slowly pull plastic panel off.   It's under the rubber molding for the rear side windows and rear window.
Also note the following:
There's a hole behind the rear side panels in the sheet metal for mounting a speaker just above the package tray on either side.
A round 6.5" speaker will fit flush.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • 96ZJ v8
  • Turtle Points: -442
  • Male Posts: 4,824
  • Member since Jun '07
  • Jeepin North Idaho
    • Buy me a drink
« Reply #3 on: Apr 12, 2013, 09:37:36 PM »
get me some pictures so i can refresh my mind. they are really easy to remove. remove all the rubber molding around the door it helps hold those panels down, and i believe there is one in the quarter window too, i think there is some plastic push clips that hold the panel on too.. those are hard to save.... can be done though,  unbolt the seat belt top and bottom. where the belt goes through the rear panel... theres a tiny trim piece that snaps into the panel... unsnap that out and then slide the belt through.  uuhhhh i might be missing something..... pics will help me remember though
1996 Jeep ZJ Laredo Daily/Weekend Wheeler
5.2L V8, 44RE, NP249, 33X12.50R15s on MT Classics, 5.5in Iron Rock Off Road Critical Path F/R
Trailer Build http://board.marlincrawler.com/index.php?topic=103261
2005 Dodge Durango Limited 5.7L Hemi Wife's Daily
84Flatbed
  • Turtle Points: -183
  • Member since Jun '13
« Reply #4 on: Sep 29, 2013, 07:12:16 PM »
I'm considering replacing my tore up headliner and if I remember right those panels would have to come off. If anyone else is removing theirs pics would be great.
Next time I see an extra cab at the junk yard I might have to practice removing the rear panels.
Last post Jul 25, 2004, 10:08:06 PM
by Skinny_Pedal
Last post Jul 06, 2008, 07:54:31 PM
by 79coyotefrg
Last post Oct 19, 2008, 10:56:39 PM
by CrawlerBrennan
Last post Nov 16, 2008, 09:20:17 PM
by ajfriz
Last post Aug 26, 2009, 03:56:30 PM
by pyrosnow911
