If a bad release bearing (throwout) is intalled properlly, then it will only make sound when the clutch is in use, ie pedal movement; with the clutch released, the noise would go away.I would be more willing to say its your pilot bearing, however I don't know what one sounds like as I've never driven a truck that had a bad pilot bearing. If it is the pilot, then you better fix it before it seezes up and takes your transmission input gear with it!! BigMike
Ummm did you put a new pilot bearing in it? Im gonna guess you didnt and now its biting you straight in the arse.....
YES Its only about $10. I change them everytime I pull the engine or trans unless its only been few thousand miles.
do you have to press out the pilot, or does it just pull out ?
than they can give me a huge hug fer me helping you...and you know i love to get dirty.happy trailsrich *ruger*
drive and find out Honestly I have no idea, if its been driving fine so far it should be just fine. But if it makes a REALLY REALLY loud squealing noise, either turn up the radio or turn the engine off immediately and get it towed. Don't even let it idle unless you keep the transmission in gear the the t/case in neutral.BigMike
if you still want to do it sun that will work(the warrenty might be the way to go, you could at least call them).do you still got that jack...it makes things easyer(if it can reach high enough...wood blocks help but it gets ghetto).i do have some hw that i need to get done...i'm gonna teach an aussie how to drive a right hand drive tomorrow around 1400.happy trailsrich *ruger*
Started by wildchild1066 Toyota Pickup/4Runner Tech 1979-95
Started by Huhwhye Engine
Started by 83MT Toyota Pickup/4Runner Tech 1979-95
Started by T-1000 Engine
Started by bluetoy84 Engine
