Author Topic: 86 Xtra Cab Exo Project, front bumper done too  (Read 19259 times)
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
I can talk all I want, because I give advice on good solid welding procedures. If you want  to do shitty welds, so be it. But anytime you want to do a full pen weld, you need to bevel, inner sleeve or no inner sleeve.
I know for a fact, that a bevel, with no sleeve is just as strong or stronger then the base metal.  You need to get that weld to go through the full thickness of the metal on a spice.
I never said that I dont bevel it along with the sleeve.  Obviously you need to bevel it to get full pnetration, plus I also put a sleeve in for extra strength.  If it does not get a sleeve and that tube sees stress under a rollover, it will snap at the weld instead of being able to flex and bend.  An inner sleeve allows the material to flex more before breaking.  If I'm in a rollover I would much rather have my cage bent than broken.  Its the difference between thinking about safety and not caring
97 4runner Limited
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Its not gonna snap at the weld. The weld is stronger then the tube.
I made some alumnum raft frames for a guy
And I know youre gonna say, its aluminum not steel. But its still the same really.  Pound for pound they are the same strength.
I did some testing. I welding two pieces together and put one end in my trailer hitch, with a cheater bar on the other end, both about 2 inches from the weld. No bevel it broke very easy. Second time I did a bevel and it just bent the tube.
« Last Edit: Jan 09, 2013, 12:51:57 PM by junya92toy »
GaJoker
  • Turtle Points: 2
  • Member since Apr '13
Anyway...Pumkin lookin good and Im liking the build, what type of bender do you use, cause you are making some nice tight bends.
1987 4Runner--SAS, 37" Nitto TrailGrapplers, AllPro EBrake, Marlin 1600 Clutch, 22re LC Engineering goodies, 5.29s ARB'ed front and rear w/ hi-pinion front (thanks Marlin).
pumkin toy [OP]
  • Turtle Points: -4
  • Male Posts: 3,561
thanks!  Im using a JD2 Model 32 manual bender with an air over hydraulic ram conversion.  for this project I used 1 1/4" pipe sized tube (1.66 OD).  The die is a full 180 degree die with 4 1/2" radius
97 4runner Limited
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Nice fab work!!!!
junya92toy I know that you know what you are talking about but sometimes the way you answer is very annoying, sort of like I know everything, you know nothing. I was building Top Fuel dragster frames before you were a gleam in your Daddy’s eye and yes if we screwed up and had to cut, it was beveled and sleeved, that was required by NHRA.
Also clean up your language, it is right in the terms and conditions that you agreed to. Marlin does not appreciate foul language, this is a family BB. You want to do that kind of stuff, go to PBB!!!
pumkin toy [OP]
  • Turtle Points: -4
  • Male Posts: 3,561
Nice fab work!!!!
thanks!
I'm hoping the customer will get some more money together so I can finish all the tubework for the rear this summer.
97 4runner Limited
nisota
  • Turtle Points: 5
  • Male Posts: 608
  • Member since Feb '12
  • Wonsyld/Leard Built Fab
Isn't the idea of this forum all supposed to be about learning so we can make our builds better and feed off others ideas for our own trucks or help them out with our knowledge? (Provided we have knowledge or experience to do so) Not needed to put anybody down or try to be better then anybody. I always love your work pumkin toy, you're an artist with a welder & tube bender.
pumkin toy [OP]
  • Turtle Points: -4
  • Male Posts: 3,561
I really appreciate the nice comments man!
you can see more of the work I do on a regular basis if you follow my business on FB http://www.facebook.com/pages/C4-Fabrication/454285357953823
97 4runner Limited
88_YotaCrawler_88
  • Male Posts: 20
  • Member since May '13
  • Yota For Life
Wow Pumpkin toy! Really like how clean everything turned out especially the front bumper being part of the cage but you cant tell until you get close! Keep Up the good work!!!! I have a friend that does metal fab and did a friends exo and I think I can say yours turned out cleaner!  :usa:
pumkin toy [OP]
  • Turtle Points: -4
  • Male Posts: 3,561
thanks dude, I appreciate the nice comments!
97 4runner Limited
Bananaclip
  • Turtle Points: 50
  • Male Posts: 106
  • Member since Mar '15
Great work! I wish you were closer to me. I like your work and design :beerchug:
84 extended cab
Last post Dec 03, 2007, 08:25:16 PM
by NaturalDisaster
Last post Mar 25, 2009, 04:05:26 PM
by COToy91
Last post May 07, 2009, 03:54:00 PM
by GJToyotabug
Last post May 08, 2014, 09:42:42 AM
by superwill
Last post Dec 13, 2018, 11:50:45 AM
by Rockcrawlintoy
