does it have disc brakes? they converted mine to all disc brakes.
Great score! Your right, hydroboost is what the big boys use, google Pirate4x4 hydroboost for a good starting point for info. Im pretty sure there is some info in a tech stickie from Billavista in there too. Just do some research before posting up there least thou be flamed! Congrats on Pumba and get some more pics for us!Mike
Just bookmarked Matt!! From a quick search, what power steering pump are you running on that Detriot diesel? Cause this site says you need a GM pump that puts out 1200-1500 PSI. And what steering box you got? If your not running a GM PS pump, your probably not getting enough power to operate the brakes. Just a thought. Here's link. http://www.thehollisterroadcompany.com/hydroboost.html
With all the torque that Diesel is making, you may want to give your T case mount a little help! If that square tube cross member is sound, you may be able to get away with replacing the tabs that are in use now with some triangular pieces of plate. Ive been eyeballin that Front Range brake kit too, looks slick!
Started by AaronB Project Research and Build-Ups
Started by 89toy « 1 2 » Project Research and Build-Ups
Started by weirdtimes_7 « 1 2 » Chit Chat Camp
Started by yoter4x4 Toyota Pickup/4Runner Tech 1979-95
Started by RovingDutchman Project Research and Build-Ups
