Interested, Is it top shift? And are the 4.7's Marlin or TGPm sent
how about 1st gen turn signal wiring harness, do you have it and how much?
I actually need the turn signal arm and mounting plate. But I think it all comes as one unit wiring harness.
What size are the rims? Are the MTRs mounted and how much tread?
Oh, I gotcha now. I know I have a at least one complete steering column. So if that's the case, what you need should be there. Any chance you'd have any interest in the compete column? I really would like to get rid of some stuff and I hate pulling small parts off of bigger parts; sometimes makes the bigger part worthless. If I'm remembering right, the column is tan/brown and out of an 83. May have a grey one out of an 80 too.
Just found what I needed at the bone yard yesterday. I am still in need of a bumper. And chance you have one?
The Champions are 15x8 and they're actual forged Champion wheels, not "add-on" beadlocks like they do now. (Look at Marlin's truck. These look almost the same; even the red rock rings)5 of the MTR's are currently mounted: 4 on the beadlocks and what was my spare on a basic 15x8 black steelie (almost new wheel). That "spare" is the best of the tires at about 75-80%. The other tires are all quite trailworthy with the lowest one being around 25-30% tread. There are two remaining unmounted tires. One is being vulcanized already, I just have to pick it back up at some point. The other needs vulcanization for a hole that I can't even see but also has some bead damage caused by a tire machine. It may still be useable on a beadlock, but I doubt it'd work on a regular wheel anymore.Here's a link to where I have them advertized:http://board.marlincrawler.com/index.php?topic=90476.msg1020960#msg1020960
Ok I have a set of 15" bead locks already, Im looking for some 17s so I can get the new MTRs
yes im also interested in the 4.7 gear set and bud built X
what would you ask for just the 4,7 gears
Do you still have duel cases and how would we get it to California yes I am interested edlp007@gmail.com
interested in 4.7 gear only...would you part out the gear set?
Started by Scott39 « 1 2 » General 4WD Discussion
Started by KYOTA Engine
Started by UNBREAKABLE « 1 2 ... 14 15 » Project Research and Build-Ups
Started by Snowrunner Parts Wanted
Started by wildcurrent Project Research and Build-Ups
