Author Topic: cracked frame suggestions and fabrications  (Read 3577 times)
4-lo
  • Turtle Points: -80
  • Male Posts: 752
  • Member since Dec '05
  • build tonite crawl tomorrow
« on: Oct 31, 2012, 09:09:21 PM »
Ok so I hit 65+ and the ride starts to rattle like unbalanced tires but futher investigation I found this..
4-lo [OP]
  • Male Posts: 752
Re: cracked frame suggestions and fabrications
« Reply #1 on: Oct 31, 2012, 09:11:14 PM »
What are some ideas out there.  Looks like the hanger and mount has to come off.
4-lo [OP]
  • Male Posts: 752
« Reply #2 on: Oct 31, 2012, 09:11:48 PM »
And lets see some pic of any like this
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #3 on: Oct 31, 2012, 09:19:04 PM »
Well that's not good at all, where is it located on the frame? Front, middle, back? Looks like the front. I'd cut off the front in front of the firewall and add some rectangle tube. Like this guy did, pics towards the bottom of the page
http://www.pirate4x4.com/forum/toyota-truck-4runner/1029246-khione-runner-3.html
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #4 on: Oct 31, 2012, 09:25:31 PM »
weld it up and brace it
Do you need a Hammer?
4-lo [OP]
  • Male Posts: 752
« Reply #5 on: Oct 31, 2012, 09:27:58 PM »
Its in the front just right behind the hanger you can make it out in the pic
4-lo [OP]
  • Male Posts: 752
« Reply #6 on: Oct 31, 2012, 09:40:40 PM »
Another angle
Teran H.
  • Male Posts: 44
  • Member since Oct '12
« Reply #7 on: Oct 31, 2012, 09:48:02 PM »
damn!  :ack:
weld it up!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #8 on: Nov 01, 2012, 09:05:31 AM »
You need to plate that. I would plate all the way back to the motor mount. I would use at least .250 plate and plate both sides of each rail top and bottom. Drill holes at the end of each crack and weld the crack then grind it down and plate. Drill holes in the plates and also rosette weld the holes.
I also run a brace back on the frame from the spring hanger back about six inches.
If you do it right it will be stronger then stock.
When I do SAS's I always run the brace from the spring hanger back along the frame. It is something I feel the vendors should do when the make the hangers IMHO!!!!
OOPS
  • Male Posts: 2,561
« Reply #9 on: Nov 01, 2012, 09:07:51 AM »
damn!  :ack: weld it up!
You cannot just "weld it up", it has to be plated or it will crack again.
4-lo [OP]
  • Male Posts: 752
« Reply #10 on: Nov 01, 2012, 09:17:02 AM »
X2 thats what im fearing
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« Reply #11 on: Nov 01, 2012, 09:27:25 AM »
Like Oops said; weld, plate and brace. I'd cut the body mount so you can get a plate all the way to the front of the frame and continue it back past the engine mount. I think .250" is a bit much, I used .188".
4-lo [OP]
  • Male Posts: 752
« Reply #12 on: Nov 01, 2012, 10:53:07 AM »
f**k this morning took a bottle of degreaser to the other side and found that there is also a crack in it too.  My guess is that there is too much pressure on the hanger with little support.
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #13 on: Nov 01, 2012, 11:54:40 AM »
I cant view the pictures currently,   however my it.sounds like what happened to mine.
I welded the cracks, ground the welds down.   Welded metal to the sides of the frame to cover the welds. And then i welded square tube from the back side of the hangar along the under side of the frame.  So far so good!
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #14 on: Nov 01, 2012, 12:35:15 PM »
This is a very common problem with the solid axle Yotas, more so if you drive them hard, add drop hanger, large tires, blah blah blah. Everything rides on the front hanger and the frame at the point just behind the hanger. It needs to be braced and maybe plated. If its already cracked, it needs plating and bracing.
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,291
  • Member since Apr '02
  • 511:1 Club
« Reply #15 on: Nov 01, 2012, 01:39:42 PM »
Yikes that's nasty. Follow OOPS suggestions to the T. I was just discussing this in another thread earlier this week:
Quote from: BigMike
Get those frame cracks fixed ASAP. Don't let this happen to you on the trail:
(source: http://board.marlincrawler.com/index.php?topic=11671.330)
And I plated my frame back to my shock towers, inside, outside, top and bottom and also built this corner brace which is great for you-
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #16 on: Nov 01, 2012, 02:09:11 PM »
Corner braces as BigMike showed or a bar/crossmember crossing just under or ahead of the crank pulleys will help a ton to limit frame flexing.
4-lo [OP]
  • Male Posts: 752
« Reply #17 on: Nov 01, 2012, 05:40:16 PM »
Dont know if you can see it but there is already a steering bracket on it.  But after looking at it I think im going to brace it back to the second mount or is that just over kill??
  • Administrator
  • 511:1 Club
« Reply #18 on: Nov 02, 2012, 07:04:22 AM »
I braced mine to the second bar of my MCI shock hoop (so a bit past my engine mount). The frame has internal bracing so it's probably overkill what we are doing for just Rock Crawling, but if ya got the spare steel then why not build extra insurance and prolong the life of your rig :twocents:
Sent from my iPhone4 connected to the BigMike Network using Tapatalk
4-lo [OP]
  • Male Posts: 752
« Reply #19 on: Nov 02, 2012, 11:01:33 AM »
Thanks mike im going for the insurance for the trails.
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #20 on: Nov 02, 2012, 06:52:50 PM »
I am going to add  Big Mike's bracing..this is what I did on mine kind of like what OOP's showed:
81 Toyota Trekker 221:1
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #21 on: Nov 03, 2012, 05:06:24 PM »
Id grind out the crack before you weld it, or you will just be pissing in the wind if you grind it smooth after welding. Take off the weld re enforcement, without grinding the crack first, means you wont get any penetration.
Last post Mar 03, 2005, 02:59:52 PM
by Mike D
Last post Apr 10, 2005, 04:38:38 PM
by dirtyskivies
Last post Jan 27, 2008, 10:56:21 AM
by Plekto
Last post Jan 15, 2008, 07:57:03 PM
by Tice
Last post Dec 24, 2012, 03:51:35 PM
by toe
