checking is for a w56a version
TurboMurf,Do you still have your original stock shift handle? If so, can you compare the bends of the one we sent you with your original one? The reason why I am asking is because we have a lot of stock Toyota handles organized by application. These handles are modified for use with our short throw base and are sent out in exchange for our customer's original handles (aka returned cores). We've sold a lot of these kits and have yet to get the application wrong but mistakes can happen so I would like to know how the bends compare.It is possible for a transfer case handle to be installed 180-degrees off, but removing the t/case handle is not required to install this short throw kit. Further, it's possible that your transfer case handle is from a different application as well as your transmission handle as Toyota made many differently shaped handles based on cab design (1st, 2nd, or 3rd gen) and accommodations (bend seat or bucket seats, fuel injected or carbureted drivetrain).Please let us know, thanks!Mike
...as Toyota made many differently shaped handles based on cab design (1st, 2nd, or 3rd gen) and accommodations (bench seat or bucket seats, fuel injected or carbureted drivetrain)...
i see a blue and white 79 to 83. do you have one in that pretty rig? i didn't know you made one for those years.
Rapid prototype approved last week (ignore the incorrect shifter in this picture), should have our first actual samples done soon!!Key feature: We've included the spacing of the very hard to find and very leak-prone thick factory rubber gasket with those six spacers/washers into the base so all you'll need is simple silicone instead. This one piece short throw base will replace 8 factory leak-prone pieces.It's gonna be awesome!
How hard is 'clutchless' shifting with the shorter throw?
If you love driving your Toyota you need one...
I am trying to convince my friend to buy this Marlin short shifter over LCEs short throw. He is looking at cost, but I'm trying.I've read all the info here. What else can convince him Marlin is better?
Remember we're in Hawaii. Core charges may cost us too much in return shippng for any savings.
Started by frankenyota General 4WD Discussion
Started by LA_Fred Engine
Started by surfindave Engine
Started by BigMike New Announcements and Info
Started by tgmaul88 Parts For Sale
