Author Topic: leak from oil pressure sensor?  (Read 5316 times)
konarider1993
  • Turtle Points: -7
  • Male Posts: 101
  • Member since May '11
« on: Sep 26, 2012, 05:34:16 PM »
I got a bad leak from the sensor right below the oil filter on my 22re. Is this the oil pressure sensor? Just unplug it, re seal it, and thread it back in?
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: leak from oil pressure sensor?
« Reply #1 on: Sep 26, 2012, 06:59:23 PM »
time for a new one.
  • Administrator
  • Turtle Points: 2124
  • Male Posts: 18,289
  • Member since Apr '02
  • 511:1 Club
« Reply #2 on: Sep 26, 2012, 07:17:39 PM »
Is this an oil pressure sending unit (do you have a factory oil pressure gauge) or just an oil pressure switch?
I've seen people use pliers on the body of the sending unit which damages it and may result in a leak. There is I believe a 12mm bolt head at the base of the sender that should always always always be used.
Oil leaks suck, get it fixed quick!
konarider1993 [OP]
  • Turtle Points: -7
  • Male Posts: 101
« Reply #3 on: Sep 27, 2012, 08:42:18 AM »
Yeah its the stock sending unit. I didnt see the 12mm bolt yesterday when i re sealed it. We'll see how bad she leaks today.
konarider1993 [OP]
  • Turtle Points: -7
  • Male Posts: 101
« Reply #4 on: Sep 27, 2012, 05:47:22 PM »
I got a new one today and am about to put it in. Anyone know anything about this 12mm bolt head
  • Administrator
  • 511:1 Club
« Reply #5 on: Sep 27, 2012, 06:00:02 PM »
Here are some pics I pulled up from Google:
Ya can't see the bolt here:
But flip it over and look here:
konarider1993 [OP]
  • Turtle Points: -7
  • Male Posts: 101
« Reply #6 on: Sep 28, 2012, 09:14:54 AM »
ahhh. Well anyways it still leaked even after i got a new one! Then I took it out and took a closer look, and the block is cracked!  Right where this threads into. Someone tightened it too much I guess.
  • Administrator
  • 511:1 Club
« Reply #7 on: Sep 28, 2012, 04:02:26 PM »
HOLY CRAP THAT SUX!! It's really tough trying to seal cracks near threads.
If the crack is along the machined flanged surface (of the hole face of the hole), then you could try adding a gasket washer to seal the leak from around it, but that will be tricky with the sending unit's NPT type fitting...
I've seen ppl try JB Weld but it always leaks again eventually.
Best of luck for ya bud!
Mike
Sent from my iPhone connected to the BigMike Network using Tapatalk
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #8 on: Sep 28, 2012, 08:48:01 PM »
Goop RTV around it.   (I've done this at a few places, worked too)
Let it set overnight before starting engine.
You may get lucky.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
konarider1993 [OP]
  • Turtle Points: -7
  • Male Posts: 101
« Reply #9 on: Oct 01, 2012, 09:11:47 AM »
yeah ill figure somethin out!
konarider1993 [OP]
  • Turtle Points: -7
  • Male Posts: 101
« Reply #10 on: Oct 05, 2012, 07:17:54 PM »
so if I use jb weld, should I put it on when engine is hot or cold, first thing in morning.
Last post Oct 11, 2007, 04:02:56 PM
by Glen1978
Last post Dec 15, 2007, 02:56:10 PM
by Glen1978
Last post Feb 05, 2008, 05:43:21 PM
by Tallchevy
Last post May 21, 2009, 07:15:12 PM
by ChrisA
Last post Aug 02, 2011, 09:49:37 PM
by weakyota91
