You have a build thread for that truck??? I'm interested in doing that to my truck
I don't really have a build thread per say. It's kind of an un-build with boring mods you can't see. The whole pont of the truck has been daily driver/wheeler and to prove you can do just about everything with 31s a healthy and low suspension setup and lockers and overall it has been a success. It's nearly as capable as my really built 4Runner with 35s. Sleepers are really fun on the trail and nothing ever breaks because of the small tires.I can post up some pics of the front suspension for you if you want and try to recreate the setup but there's not much to see. You just redrill the spring pin holes in the top three leaves to match the location of the stock fronts, then add a bit of the stock front bottom leaves, maybe 2 and a shorty overload, maybe a trim packer about 8-10" long on the drivers side to compensate for the lower spring perch. I also made some moderately longer shackles out of these conduit hanger plates I got from Home Depot. You can drill out the holes on one side and press or hammer the stock shackle pins in. In the front I bent the plates over an anvil to get the bent plates like stock. Your lift shackles should be just perfect. Then just do whatever you have to to get some really long shocks in there that don't top or bottom out hard. I'm still using stock bump stops too.I'll try to get you a pick of the finished product when I rotate my tires...
Started by Prismo Tow Rig and Trailers
Started by Rocksurfer Chit Chat Camp
Started by Cheesemaker Chit Chat Camp
Started by BigMike Toyota Pickup/4Runner Tech 1979-95
Started by Speed Toyota Pickup/4Runner Tech 1979-95
