The reason your servo is twitching is cause your ESC (electronic speed control) isn't supplying your servo with enough power, basically your servo is starving. The best thing you can do is buy a 20$ BEC or buy a 6$ glitch buster.. If you have an open spot on your receiver then just get the glitch buster and plug it in . The other option is the BEC witch you can have programmed to the proper voltage your servo needs and will take some solder for install.. Hope this helped
if ya cant pork a princess, pound a pig!!!Lower the standards, raise the average!
Id say you nailed that one on the head! My buddy had a wraith that did the same thing and we bought the bec and wired it in and he ended up swappin to a dual lipo set up on a new esc and kept using the BEC. its a good investment!
Yeah it's the best investment to have the proper power to a servo. Most servos will require about 6v to around 7.4v. Depending on what the max input is you'll have the max amount of torque . Most ESC will only supply around 5v. I run a BEC on my comp rig and my wraith. Be carful tho, it's an addiction haha
Clean set ups!! Diggin the wraiths body panels...aluminum??
Im diggin it! The losi is rockin a vette z06 body till i find one i like to paint....but rc's are on the back burner till i get me a yota rig and slightly build it! No pics of it with the vette body yet though
Its a 10th scale...good ol losi nightcrawler..got it on sale with my sweet spektrum radio for right at $250....they had to rob the receiver and old remote for a in store warranty for someone else...so they marked it way down and threw in the radio for free!!
Started by sumedumbkid General 4WD Discussion
Started by donkeykong RC Rock Crawler Tech
Started by rrick Toyota Pickup/4Runner Tech 1979-95
Started by Gewehr43 General 4WD Discussion
Started by I.D.G.A.F RC Rock Crawler Tech
