Author Topic: 85 Ext Cab Red Truck Build  (Read 94173 times)
SqWADoosh
  • Turtle Points: 10966
  • Male Posts: 2,417
  • Member since Oct '14
Re: 85 Ext Cab Red Truck Build
« Reply #270 on: Mar 13, 2016, 04:58:12 PM »
Sick build  :thumbs:
boomtacoma01 [OP]
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
« Reply #271 on: Mar 14, 2016, 05:48:18 PM »
Thanks man. Yours is looking good too.
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #272 on: Mar 26, 2016, 06:59:26 AM »
I've been out of town since getting back from K2. It is truly an awesome park to wheel and is definitely hard on your rig. I think once the tire break in they will be awesome. Issues that I found: I need to clearance both front fenders, cut off about 2 inches of slider in the front and rework my winch situation. My tires eat into the sliders and fenders when stuffed and my approach angle is horrible.
On to the pics..
King of the Hill
https://youtu.be/7Z_p4CR1XMQ
My tires hit the leaves a little.
Daniel losing his idler and steering pump pulleys on Smoking butthole.
Alex on Crazy Wabbit
Ron doing his thing on Dolphin
Guy named Rob with a sweet fj55 buggy and a hot 5.0 under the hood
Ryan's Twisted Customs buggy on Kiss My Grits
Ron on Hanibal Lecter
Exit on King of the Hill
Weather was perfect!
IG @boomtacoma01
Dwill817
  • Turtle Points: 395
  • Member since Jan '14
« Reply #273 on: Mar 27, 2016, 02:45:43 PM »
Definitely looks like you gained some turning radius!!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #274 on: Mar 27, 2016, 05:12:41 PM »
Yep. I realized after I got back that my steering stops were adjusted all the way in. My high backspaced wheels don't help the situation either
IG @boomtacoma01
Dwill817
« Reply #275 on: Mar 27, 2016, 05:37:50 PM »
A Toyota axle won't turn like that second picture you posted!
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #276 on: Mar 27, 2016, 05:54:23 PM »
That 60 doesnt like turning like that either lol. That's an outer axle killing good time. Seen it many times. Once you set the stops out a bit it helps a ton.
01 double cab hunting truck
06 tacoma street truck
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #277 on: Aug 14, 2016, 10:22:36 AM »
I attended Lonestar Jambo 11 in May. The truck did well and I had a great time.
We found some mud on Thursday night
Todd getting Tippy
Brandon on Dewoody
Nathan at the top of Old Town Trio
Todd coming down Shake Rattle and Roll
tire problems for me again
Kevin and Alex
Randy ramping up on the Squirrel
F*** Mud
A little nosedive by me
Ol Red and his buddy the Dirt Squirrel
I had another wheeling trip  at Superlift ORV in Hot Springs Arkansas.
This park is awesome! There was some rain and it was slick.
Video of Horsepower Hill wrapped out at 5500 rpm!!
Video of Alex took a harder line and was a little more impressive than mine
Daniel warming up his tires
Got 2 tires off of the ground on Schaffers
Hills galore
Our group for most of the weekend
Alex on Pinion Hill
Red doing work
RTI still had a little to go
headed home
I have been putting in a bit of work lately.
I cut the outer rail and Kickouts off of my sliders. They stuck out way too far and were more of a hindrance than a blessing on my past few trips. I will refit the Kickouts to reweld to the rear of the sliders. I also trimmed another 2 inches off of the front of each slider. The 40's kept digging into them at full stuff and on hard turns.
I stripped down the interior of the truck in preparation for the Auto Swap.
I have pulled the Duals and am in the process of pulling the transmission. I have them sold and should have enough to drop on an Atlas II 4.3. I removed the clutch peddle, slave cylinder reservoir, hard line and starter.
I found an A340F at a local yard for a decent deal of $300. I ordered  the Advanced Adapter 50-5710 adapter to fit the A340 to the Atlas. I also replaced the 3 solenoids in the transmission pan and need to install the Transgo 340 HD2 shift kit after the new valve body gaskets come in.
I also ordered some miscellaneous brackets and tabs to make the transmission cross member. Dave @ Brave Motorsports is going to Fab up one of his tail housing supports for the Atlas.
Since my truck was a manual and will be keeping the stock wiring harness, I went with the RADesigns Baja Shifter to manually control the transmission and the Rock shifter for the trans gear selection. I will have to fab a mount for the 2 shifters and adjust my transmission tunnel cover accordingly.
I will be adding an external TransCooler (Derale 13950) and ordered all of the -6 fittings and hose to plumb it in.
« Last Edit: Aug 14, 2016, 10:29:45 AM by boomtacoma01 »
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #278 on: Aug 14, 2016, 10:33:37 AM »
A340 with the R series bellhousing
Swapped out the solenoids
Trimmed down the sliders
Cab cleaned out
Down to 2 peddles jamminzz half way there
Ready to drop the transmission.
Almost have my winch mount wrapped up
It's tucked in a lot better than before.
The tube is 1.75 DOM .188 WT. I used a piece of 4" channel iron for the winch base instead of the 2" square tubing like i originally planned. I had to use 4 socket head grade 8 bolts instead of the regular ones due to space constraints. I capped off the Skys Offroad Lettering with a peice of 3/16 x 1.5" flat bar. Never Liked that on there anyways. I also trimmed the front grille to fit around the winch. I still need to fab up a mount for my steering cooler and run the wiring for the winch but other than that it's done.
I also finish welded the kickouts on my sliders, capped off the front where I trimmed them back and finally got my transmission pulled.
The Front 3 Link parts have started rolling in as well as some PSC goodies for a Full Hydro steering setup.
I'm not sure how soon I will get to start on that though.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #279 on: Dec 26, 2016, 04:54:50 PM »
I have been slacking on updates.
Finished up my slider modification with the trimmed down kick-outs on my sliders and capped off the front.
I finally got the R151 dropped and cleaned up. I did a quick tear down and inspection of my duals and got them sealed back up. They have a new home now
I have been working on stripping down the front end in preparation for the 3 link. The D60 is sitting on jack stands waiting for the old brackets to be cut off. The Plasma list is pretty long...
The transmission is ready to install. The RAD Designs bracket, lever and shift cable are installed. The Flexplate and dust cover are installed and torqued down. I still need to get some Dex 3 or 6 fluid. Transmission cross member is mocked up and needs to be cut, fit and welded up.
3 Link parts are piling up around the garage.
a TG 7.3 orbital and mount
a PSC XR 2.5 DE ram, clamps and clevis kit
Barnes 4wd and Artec lower link brackets/tie rod links
Artec adjustable upper axle link
Rockwell Offroad 1.25 heims, misalignment spacers and tube adapters
RuffStuff Panhard brackets, 7/8 heims and 4 ft of 1.5 .25 DOM
24' of 2" .25 WT DOM for the links
I also finally got a set of beadlocks to hopefully cure my tire woes.
They are fairly new on the market and are a joint venture between TrailReady and American Eagle Alloys.
TR Hardrock - Series 025 - TRUE BEAD-LOCK (Single Wheel)
1 down 3 to go..
This wheel and tire combo is growing on me. I hope they work as well as they look.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #280 on: Dec 26, 2016, 05:00:48 PM »
I got the second tire mounted up on Wednesday substantially faster than the first one. I brought the other 2 to Discount Tire to get dismounted today. I had the chance to use my Thermal Dynamics plasma last night. Besides being an older model, this unit blasts through steel with ease. I trimmed the front leaf spring hanger, driver side body mount, ifs steering box mount and some inner frame brackets. I also cut the front fenders a little higher, deleted the parking/turn signal lights and reinstalled the fender molding. Plan for this evening and weekend is to burn off the D60 leaf perch, hydro steering  bracket and shock mounts. I also mocked up my orbital steering valve and made a nice place for it to mount where the IFS steering box was located.
Mounted the tires on the 14b. I had to order some small diameter lugs which should be here on Tuesday.
Since the Interior was torn down I built a subframe for my Corbeau seats. I never liked how little headroom I had with my cage. When I tore down the interior my front seat mount was shot and I needed to replace some of the floor pan so out it came.
I cleaned out the floor pan some more and put another couple of coats of Bedliner in a can.
Cleaned up the frame and body mount. I'm running the upper link frame mount here.
Orbital mount finished up.
AtlasII 4.3 mocked up on the A340F.
Initially fit into place. This will make my seat mount a little difficult.
Big hole in the floor. I have to relocate the fuel return lines here. I also need to figure out some sort of skid plate for the transmission pan. A little too exposed for my liking.
Frame mount upper link bracket with panhard mount tied in.
Rad Designs Shifters mocked up for manual control of the Transmission.
I cut a new plate for my transmission tunnel cover and got my shifters mocked up.
Since my radio fried at Hot Springs during the monsoon, I decided to make the radio area a spot for some switches. They will control various lights, the trans cooler and some other things. The trans temp gauge may go in there as well since I have the room.  I need a few more rocker switches to finish it up. The plate is a piece of stainless sheet metal that I had laying around and I have about 10 bucks in switches invested.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #281 on: Dec 26, 2016, 05:03:13 PM »
A little more progress...
Blue Torch Fab full hydro mount and PSC XR 2.5x8 DE Ram
Mocked up
PVC mock up links in place on the Driver side. Ended up with a 32 in upper and 39" lower.
I had to throw a tire on to see what it is going to look like. Itis 5 inches off the ground in the picture.
I started on my transmission X-member and skid plate. Its has been a challenge to say the least. I have to work round the exhaust and driveshaft and a few other things. I almost have a complete flat belly right now. The Atlas is hanging down about 1.5-2 inches below the frame. It will be mounted with 6 bushings to the frame rail.
Then, I need to drop the trans and TC to get them bolted together completely and install the Torque Converter and reinstall.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #282 on: Feb 08, 2017, 09:08:34 PM »
I finally got the A340 and Atlas together and sealed up. I burned in the crossmember mounts and skinned the transmission/ transfer case skid with a piece of AR500 plate.
I will be adding another crossmember for a tail support for the Atlas.
I ordered some more parts from Barnes4WD to finish up some small things and will be fabbing up a cover for that gaping hole in the floor.
I should be ordering up my Fox 14"coilovers from Ryan at Accutune after KOH.
Then I need to cut out my old shock hoops and fit my 4WheelUnderground shock towers on the frame rail.
There is still a lot to do.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #283 on: Feb 08, 2017, 09:10:38 PM »
I fabbed up a cover for my floor pan. Front cover will be removable to access the front driveshaft.
I got my Derale trans cooler mounted.
I got my transmission flexplate and TC bolted up and my starter re-installed.
I need to reinstall my header and muffler, fill the trans and Atlas, plumb the cooler lines to the transmission and proceed with a test fire on the engine.
IG @boomtacoma01
Peterbuilt84
  • Turtle Points: 12
  • Male Posts: 1,049
  • Member since Sep '09
    • Poly Goats
« Reply #284 on: Feb 16, 2017, 09:32:56 PM »
Badass! Coming along great :smokin:
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #285 on: Mar 11, 2017, 10:01:43 AM »
Transfer case cover finished with the integrated seat mounts.
http://s241.photobucket.com/user/boomtacoma01/media/85 Toyota/22518771-D234-4235-BD48-033E033C9B94_zpsv71qi9vm.jpg.html][/URL]
I found a set of the liquid sounds shallow mount speaker pods with a set of Kicker 6.5" coax speakers.
http://s241.photobucket.com/user/boomtacoma01/media/85 Toyota/F18B0092-109E-477A-80B0-9009DBE8B406_zpsxdtzusla.jpg.html][/URL]
Most importantly I started mocking up my Fox 14" coilovers. I had to cut off the shock hoops, move them forward about 2.5" and kick them back about 10 degrees. The lower shock mounts are from Artec and integrate to the lower link mounts. The upper shock hoop mounts are from Wide Open Design.
http://s241.photobucket.com/user/boomtacoma01/media/85 Toyota/1E4F517D-DF6B-49A9-A1F0-B230268E5137_zpsofwerr6w.jpg.html][/URL]
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #286 on: Apr 02, 2017, 08:45:52 PM »
I had a chance to work in the truck for a solid 3 days. I got the front welded out and painted. Both coilover mounts are done. The full hydro is mounted and the lines are plumbed. I finally finished mounting my last tire and torqued it to spec.
I mounted the front grille and welded in the driver side seat mount.
I should have a roller by the end of the week when I get my coilovers back from Brave Motorsports. I'm pretty excited. It has been a long time coming.
IG @boomtacoma01
Willard
  • Turtle Points: 1608
  • Male Posts: 627
  • Member since Dec '14
« Reply #287 on: Apr 03, 2017, 12:50:04 PM »
Just an observation here. Are you planning on building a plate to protect the ram? If so good...if not you may want to consider.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #288 on: Apr 04, 2017, 11:33:57 AM »
Yes, I have some plate cut to go on the bottom side of the ram mount. I am looking at making it removable right now. If not I will just weld it in.
IG @boomtacoma01
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #289 on: Apr 05, 2017, 01:07:22 AM »
I like those rims!
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #290 on: Apr 08, 2017, 09:56:00 AM »
We have a roller. Links are 98%, steering is plumbed in and bled,  the engine fired up after 8 months on the first crank and the auto seems to be working correctly. I'm pretty happy.
IG @boomtacoma01
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,052
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #291 on: Apr 08, 2017, 10:50:10 AM »
You're tires are mounted opposite right to left so the asymectric tread is all going the same way.  Is this on purpose?
Truck looks good.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #292 on: Apr 08, 2017, 11:40:37 AM »
They are asymmetric treads on the tires mounted directionally. You won't see too many of these out there. They may not be in there for long. I'm eyeing a new set of Sticky Treps.
IG @boomtacoma01
Gnarly4X
  • Online Gold Turtle Award
  • Turtle Points: 5134
  • Male Posts: 4,223
  • Member since Jun '16
  • 4-wheeling vicariously.
    • Buy me some coffee
« Reply #293 on: Apr 08, 2017, 02:09:30 PM »
Holy Crapity boomtacoma01,
I don't know why, but I think you are short a couple of pairs of PLIERS!!!  :yikes:
Gnarls.  :rofl:
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #294 on: Apr 08, 2017, 07:10:12 PM »
Ha ha. Those at tin snips. I had to trim a bit of inner fender out for some added clearance.
IG @boomtacoma01
Willard
  • Male Posts: 627
« Reply #295 on: Apr 08, 2017, 08:20:23 PM »
Looking great!!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #296 on: Apr 13, 2017, 11:31:57 PM »
Knocking out the little things.
Vision X Optimus pods
Bed lined out with a Pelican case for tools and and my ARB recovery gear
Interior wiring and shifters completed
Everything is good to go for some hot laps around the neighborhood tomorrow.
IG @boomtacoma01
Gnarly4X
  • Male Posts: 4,223
« Reply #297 on: Apr 14, 2017, 03:27:12 AM »
hey boomtacoma01,
It's look'n mighty "trail ready"!  :beerchug:
I would move the CB antenna.
It would be my luck to lean on a rock and rip it off!   :disturbed:
Is that antenna a top loaded Firestik?
Gnarls.
« Last Edit: Apr 14, 2017, 03:33:08 AM by Gnarly4X »
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #298 on: Apr 16, 2017, 06:15:41 PM »
It's not in the best position. But it has survived so far.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #299 on: Apr 16, 2017, 06:31:37 PM »
Well the test drive went well on Friday. I didn't push it too hard and put about 5 miles on it. The full manual control of the auto is pretty sweet. I even threw the plates on ha ha.
Just a few little things to wrap up over the next few weeks.
IG @boomtacoma01
Last post Jan 19, 2022, 01:40:16 PM
by 2G4R
Last post Mar 19, 2006, 10:20:34 AM
by pyrotec220
Last post Jan 08, 2011, 06:03:34 AM
by motoracer
Last post Feb 19, 2012, 03:41:36 PM
by yotaneck13
Last post Apr 14, 2017, 12:32:10 PM
by tgmaul88
